Broken down c5 please help. Electrical
Old Jul 10, 2014 | 09:06 PM
Daddyrama31's Avatar
Daddyrama31
awesome! Glad it was an easy fix for ya!
Old Jul 10, 2014 | 09:13 PM
chuckeb84's Avatar
chuckeb84
Originally Posted by wardamncorvette
Ok I got the battery removed... If I give it to advance I save 18.00 core charge. Gonna end up costing about 68$ for new battery. If I get the 109$ one. Not sure but prolly going with the 116.99 one.
Below is a pic of under battery tray. Doesn't look bad
If you're going to keep the car.
Some day remove that tray and clean out the rust and prime the frame.
Nice job
Old Jul 10, 2014 | 09:15 PM
wardamncorvette's Avatar
wardamncorvette
St. Jude Donor '14-'15
Nice job
Oh yeah I'm keeping it!
Thanks man!
Old Jul 10, 2014 | 10:35 PM
NatB's Avatar
NatB
Suggest if you did not do so that you remove the plastic battery tray and then closely inspect the area underneath for acid leak damage. Paying particular attention to the top of the PCM, the electrical wiring bundles , and the HVAC vacuum line tubing. If acid damage is present , neutralize to halt further damage.
C5 battery placement over key wiring and vacuum lines was a poor design. I use only Optima Batteries because of this issue.
Old Jul 10, 2014 | 10:56 PM
wardamncorvette
Will do!
Thanks!
Old Jul 11, 2014 | 04:34 PM
donald4972's Avatar
donald4972
What battery size is recommended?
75, 650 cca
78, 700 cca
75-3, 700 cca
75 690 ca
Get the biggest (most CCA) you can find. The big Die Hard has 850. Other brands as well, I imagine. Do not try to save a few bucks here. C5 is notoriously hard on batteries.
Don
