I recently got my C5, so I am still in the exploration stage with some things.
I notice that the gauge that displays the readings for climate control is extremely dim.
All the other instrument gauges are nice and bright.
I thought maybe there is some sort of clear film placed over the outside to protect it from scratches, and in all the years the previous owner never bothered to remove it.
Close inspection and I don't think there is a film over it.
Why would this be so dim ?
Hardly able to read it unless I lean over and put my face about five inches away from the gauge.
Any suggestions?
Bob.
Any suggestions?
Bob.
You can also get a used part for $200 and replace the whole thing from Corvette Recyclers. I did that, but I should have read the forum in more detail and done the solder routine first.
Correctly soldering the 8 resistors shown in the link provided will fix your display for zero dollars if you can take out the HVAC head unit and solder. I did mine last week, it took about 40 minutes to take out, solder and put back. It could be done quicker, but I wasn't in a rush.
A quick search on the forum finds an easy fix that I just did today, very good instructions and no more guessing what your temp is. I was a first time with soldering and it only took about 30 mins. Had the dash apart for a new shifter. Totally worth it and satisfying to just complete diy. Mood luck
