engine bolt ons question
Old Jul 14, 2014 | 04:55 PM
maybelooking's Avatar
maybelooking
Default engine bolt ons question
So I have a 2004 CE vert and am thinking about modding it. My last vette (98) had heads, cam, LTs, intake, pretty much every bolt on you can do.
My question is, if I did all those bolt ons, but used the factory cam, or maybe an LS6 cam, because I want this car to idle like a completely stock car.....how would those other bolt ons respond?
I really like the idea of the car sounding almost stock.....so I would leave the factory mufflers on.
I would imagine the heads and headers along with an LS6 intake would still really wake the car up......but leaving a stock cam and mufflers on it would make it sound really close to factory?
thoughts??
Old Jul 14, 2014 | 05:01 PM
Blow Torch's Avatar
Blow Torch
The heads, headers will help. You already have a Z06 intake (2001+) so you will definitely wake the car up.
Cams are a popular mod because most LIKE the sound, and you can pick up some really serious hp.
I don't think I would bother with a Z06 cam unless you are SURE you will never go bigger. Its a lot of work to do for such a small increase (IMO)
Old Jul 15, 2014 | 07:04 AM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Old Jul 15, 2014 | 07:26 AM
rjwz28's Avatar
rjwz28
thoughts??
Also, you can get SIGNIFICANT gains without losing the OEM nature of the sound if you install a well-specified, lower-duration cam. I believe PRE-Z06 and a couple others have had great luck with big gains and serious power under the curve from smaller cams.
Old Jul 15, 2014 | 07:52 AM
F&Yb0dluvr's Avatar
F&Yb0dluvr
Check out Texas speed's sleeper cam
https://www.texas-speed.com/p-1145-t...-camshaft.aspx
If you want the car to sound nearly bone stock you could try a sleeper cam like that, some mildly ported 243 heads, headers,X pipe , high flow cats and throw in some Z06 mufflers
Old Jul 15, 2014 | 07:59 AM
bikeriderga's Avatar
bikeriderga
Agree. You can get a good performance cam that will idle well if you get the right tune with it. It is all about modding correctly (matching components), not just sticking mods on it.
If you do not know the best mods, reach out to well known Vette performance shops and get their opinions and advise. They do this for a living and know more than us tinkerers.
Old Jul 15, 2014 | 08:09 AM
maybelooking
well my last cam was a 224/224 600/600 on a 115 and I thought it would idle really well.....and it didnt. I dont know what lobe profile that cam was and Im sure the tune sucked......but with this new car im just really hesitant to put a cam in it.
I want a smooth idle with absolutely NO surging issues at all.
Old Jul 15, 2014 | 08:15 AM
bikeriderga
Old Jul 15, 2014 | 08:19 AM
rjwz28's Avatar
rjwz28
Where are you?
Old Jul 15, 2014 | 08:46 AM
maybelooking
Originally Posted by rjwz28
Where are you?
Memphis, TN.
I will do the work myself, but the closest place I know of to get the tune done would be Vengeance in GA. Theres not a tuner in Memphis that I would trust.
Old Jul 15, 2014 | 08:58 AM
rjwz28's Avatar
rjwz28
Memphis, TN.
I was more asking for the purpose of you getting with one of the guys on here with a little cam that puts out and idles nice
That'd be the way I'd go
To engine bolt ons question
