Driver side headlight help
Old Jul 23, 2014 | 02:20 PM
johnsos30's Avatar
johnsos30
Default Driver side headlight help
I have H I D projector headlight housings and 55 W low beams. After a while, my driver side headlight went out. Switched the HID bulbs from driver-side to passenger side but driver-side was still out and passenger side always worked. I checked fuse 8, 9, 10, and 12 under the hood and they are all fine. Can anyone help me diagnose this problem so I can have both headlights working again?
Thanks in advance!!
Old Jul 23, 2014 | 03:04 PM
MAC5's Avatar
MAC5
Thanks in advance!!
From your description sounds like a ballast or wiring issue on the drivers side.
Old Jul 23, 2014 | 03:05 PM
johnsos30's Avatar
johnsos30
Ballasts are good. Switched bulb and ballasts from driver side to passenger side. What wiring issues should I look for?
Old Jul 23, 2014 | 08:21 PM
johnsos30's Avatar
johnsos30
Ttt
Old Jul 23, 2014 | 09:33 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Double check fuses again -- I had a similar issue last week and it turned out to be a bad fuse. If that is not it, grab a digital multi-meter and check the headlight harness for power (12 v) and ground (0 v).
Old Jul 23, 2014 | 09:49 PM
drag477@yahoo.com's Avatar
drag477@yahoo.com
Thanks in advance!!
having the same problem narrow it down to the relays but, unable to get in touch with jw for replacement relays. sent email no response from them.
Old Jul 25, 2014 | 02:21 PM
johnsos30's Avatar
johnsos30
How did you narrow it down to the relay?
Old Jul 26, 2014 | 09:12 PM
drag477@yahoo.com
Default response to your question
I checked the wiring, bulbs, the same thing you did. Then the only thing left was the relays, when I went to pull the relay from the harness, I noticed that one of the terminals was pushed up into the relay which the little fine copper wire was broken from the terminal, so I lightly soldered it . plus I switched the left relay to the right and it lit up so I did the same for the left and it lit up . problem solved . relay. Now if you turn the lights on and the car's not running only one light will light, but if you start the car both will come on . weird! So jw is sending 2 new relays. Hope this is helpful.
Old Aug 20, 2014 | 12:22 PM
johnsos30's Avatar
johnsos30
Checked the ground and cleaned it up. Still no go. Can someone tell me exactly how to check to see if it's getting power? Is it a relay? Fuses are fine. Step by step would be nice. I'm not too go with electric car issues but wanna learn.
To Driver side headlight help
