[Z06] Fast 92 ?
Old Jul 27, 2014 | 02:29 PM
newbs49's Avatar
newbs49
Default Fast 92 ?
Have a guestion for performance guru's. 01 Zo6 with headers, cam
572 578 114lsa, Texas speed 2.5 LS6 cnc ported and polished heads.
Is adding a Fast 92 with Fast fuel rails and LS2 thortle body worth the extra $1300 for these parts. Any ideas would be appreciated.
Old Jul 27, 2014 | 03:31 PM
Tar Heel's Avatar
Tar Heel
We are in the same situation now and have done much research. If you use your search function there are many threads dedicated to just this topic. We have a bolt-on C5 (max effort track car) and are in the process of gathering parts to go H/C. Hoping to break into the 9s on a small shot of nitrous and run solid 10s NA. I guess it all depends on your goals and what you're willing to spend. For that amount of money you'll only going to gain 15-30 HP at the wheels depending on what you read. Is it the best bang for your buck? Most likely not but again it's about what you're trying to achieve and what you're willing to spend.
Scott
Old Jul 27, 2014 | 03:48 PM
newbs49's Avatar
newbs49
Thanks for the reply. The intake seems to be 10-15 with throttle body. Is it worth it for that, maybe not. Just looking for info and peoples thoughts. Thank you.
To Fast 92 ?
