Door Panel Access Plug Cover
Old Jul 28, 2014 | 10:54 AM
Paddy's Avatar
Paddy
Default Door Panel Access Plug Cover
I just recently purchased a 2003 convertible with only 20k miles, but the access plug on the drivers door has fallen out twice. Anyone else have this problem? I have installed a new one, but it came out after a couple of days.
I have a 63 split window and I know a lot about the issues with those, but I am new to the C5 world - Any suggestion?
I am also ordering a steering column lockout(?) protector - Any thing else I should know? Brand new battery, by the way.
Old Jul 28, 2014 | 11:01 AM
Cutlassmaster's Avatar
Cutlassmaster
Use some double sided sticky tape. I had the old ones fall out and after replacing with new ones same thing happened a year later. I used tape and have had no issues since.
Chris
Old Jul 28, 2014 | 11:07 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Sounds like you got the two main ones (battery & LMC5/CLB) right off the bat!
Here is some useful info
http://forums.corvetteforum.com/c5-t...l-in-here.html
Congrats on your C5! Pics of the '03 and '63?
Peter
Old Jul 28, 2014 | 11:09 AM
jrose7004's Avatar
jrose7004
Use a little bit of adhesive on them.
Old Jul 28, 2014 | 11:14 AM
dubtrub's Avatar
dubtrub
I'm not sure an '03 convertible has a steering column lock. My '02 coupe does not. I think those were terminated in 2000 or before.
Old Jul 28, 2014 | 11:38 AM
Paddy's Avatar
Paddy
Thanks to all who replied - I will try the tape and I am also working on posting some photos.
Paddy
Old Jul 28, 2014 | 11:44 AM
That should work - just use some very thin double sided tape so the plug doesn't stick out away from the door panel.
Old Jul 28, 2014 | 04:18 PM
C5Txfan's Avatar
C5Txfan
That's true for autos ... 6 spd still has them.
Old Jul 28, 2014 | 04:36 PM
Phanni's Avatar
Phanni
There are three tabs on the access piece. They are very fragile and will snap off very easily. the side with two tabs goes towards the bottom,.
Place the piece with the bottom side in place, then gently push in the top side. If the any of these tabs get broken, the tape will suffice.
Old Jul 28, 2014 | 05:47 PM
Lee DeRaud's Avatar
Lee DeRaud
Might help to know which "access plug" we're talking about, because the same fix won't work for all of them. Is it the plastic widget under the door handle, the rubber plugs along the bottom edge of the door frame, or the red plastic reflector?
Old Jul 28, 2014 | 05:53 PM
RedZMonte's Avatar
RedZMonte
I got new plugs from the dealer for like $4 ea.
Old Jul 28, 2014 | 09:15 PM
Paddy's Avatar
Paddy
It is the cheap plastic plug that is located behind the door handle - I got a couple of spares form the dealer today - but the price for mine were $5.39 each - Thanks for the help guys - The sticky tape hopefully will hold it in place. Love the car!
To Door Panel Access Plug Cover
