Best battery
Old Aug 18, 2014 | 10:26 PM
yanmar's Avatar
yanmar
Default Best battery
The vette may stand for 3 or 4 days without being driven , what battery would you suggest i buy ?
Old Aug 18, 2014 | 10:37 PM
65GGvert's Avatar
65GGvert
There are hundreds of discussions about it on the forum that you can read and see if you agree with the arguments.
My personal favorite is the stock Delco, and 2nd choice is Interstate. The model depending on what year car you have. (Side or top terminals)
My least favorite is any of the Optimas. Now watch this.
Old Aug 18, 2014 | 11:01 PM
I like the Sears DieHard Platinum - have had it in my car for nearly four years now after an Optima Red Top died after only 3 years of use. Have had absolutely no problems at all with the DieHard.
Old Aug 18, 2014 | 11:21 PM
LT1driver's Avatar
LT1driver
very, very subjective. I like delco 78 pro, autozone gold and least liked and wouldn't put in anything is optima of any color....good luck with choice.
Old Aug 19, 2014 | 12:05 AM
Rexde1's Avatar
Rexde1
I got three years out of my last Autozone battery.
Old Aug 19, 2014 | 12:13 AM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
C5 is famously hard on batteries. Whatever brand you get, buy the biggest battery you can. The most CCA (cold cranking amps) available is needed here. Don't try to save a few bucks, when buying a battery for C5 Corvette.
I have the big Die Hard Platinum also. It has 850 CCA's, and always feels strong.
I would advise you don't get a smaller battery, than that, what ever the brand.
Don
Old Aug 19, 2014 | 12:37 AM
racebum's Avatar
racebum
anyone check into the costco warranty? it's supposedly 100months pro rated
if you changed out batteries every 3 years that would make it cheap to keep a newer battery in the car. for a wet cell they have decent cranking amps too
Old Aug 19, 2014 | 12:43 AM
stu12dozen's Avatar
stu12dozen
Old Aug 19, 2014 | 02:31 AM
04 SneakySleeper Z06's Avatar
Everyone has their own opinion. IMO the optima yellow top deep cycle is a beast, just dont be an idiot and act like it's an never ending power source. (For some reason when people get an Optima battery they forget this and then are surprised when they have issues). Typical batteries need to remain close to a full charge. The beauty of a deep cycle (yellow top) is it can actually wear as low as 60% and still have the cold crank amps to fire up. ...again just dont abuse it.
My favorite part is that it's a gel battery that won't leak, which is huge being that the on board computer is just beneath it. *invest a little extra & avoid A LOT :-)
Old Aug 19, 2014 | 02:41 AM
Architect's Avatar
Architect
Any dry cell AGM. The battery is simply too close to electronics for anything other.
I bought an Exide Orbital in 2007 still going strong. Half of its life has been battery tended. Orbital was replaced by the Exide Edge. Get a 78 series.
Old Aug 19, 2014 | 02:42 AM
racebum's Avatar
racebum
all true
except you forgot the part about them dying in about two years tops if you use them in a daily driver
red tops are far more suited to frequent use in the auto environment
Old Aug 19, 2014 | 04:51 AM
Cliff8928's Avatar
Cliff8928
After fixing the vacuum line near the PCM being eaten through I wasn't going to take any chance with a conventional battery like the previous owner installed.
I used a Duralast Platinum (AGM) from AutoZone and it's been good for 2 years so far. After sitting all winter disconnected in an unheated (albeit insulated) garage, it starts like any other day. There wasn't one listed for my 2004, but I used a 34DT which is the same size as the 78, but with added top terminals required for the '04.
Old Aug 19, 2014 | 07:05 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
I like AC Delco. Had Die Hard and it didn't last long.. maybe 2 years. I've gotten 9 years out of an original AC Delco I had in my 96 Camaro. Now they are rated at 5 and 7 years and that is exactly how long they last. Just replaced a 5 year one after 5 years. They are bit pricey from the dealer though but they are strong batteries.
Old Aug 19, 2014 | 07:40 AM
MAC5's Avatar
MAC5
Exide Edge, formerly known as Exide Orbital
Old Aug 19, 2014 | 07:51 AM
mjmc1273's Avatar
mjmc1273
I got 8 years of service out of a Optima Red and only replaced it because I sold the car and never want the next guy to worry about having an old battery that might crap out any day!!
Old Aug 19, 2014 | 08:08 AM
rwlc5's Avatar
rwlc5
I have had an Optima red top for about 12 years. I keep it hooked to a battery tender when not in use.
Old Aug 19, 2014 | 08:21 AM
7LitreC5's Avatar
7LitreC5
Still a fan of the Optima Red Tops. The Red top in my C5 is almost 10 years old and still working fine.
To Best battery
Old Aug 19, 2014 | 10:06 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I've used Red Tops. Suggest using a trickle charger like a CTEK3300 all the time. Got six yrs plus on my last Red Top & only changed it to be on the safe side. Good luck!
Old Aug 19, 2014 | 10:12 AM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
I had an optima yellow top last almost 10 years. No battery tender and not a lot of use. Recently I have been going with the Advance Auto Gold batteries simply because of the warranty. I really don't care if my battery dies early because they will give me money back towards a new one. Combine that with the coupon codes they have floating around and you get a new gold battery for $100 tops. As much as I loved my Optima, I just can't justify spending double for the same use.
Old Aug 19, 2014 | 11:53 AM
VETJAZZ's Avatar
VETJAZZ
Everstart MAXX at Walmart for under $100. Works great with 5 year warranty and 2 year free replacement.
