When you depress the "OPTIONS" button on the side of the gauge cluster you will see an option for "EASY ENTRY/EXIT" display in the DIC. From there you can simply toggle it on or off.
Note that if you have the memory option in your car with the dual fob setup then this completely overrides the seat sliding back for both fobs (both drivers). The seat would then only change either by you physically moving the seat via the controls or by selecting either "1" or "2" on the memory option.
