[Z06] fast 92 or 102?
looks like I'm going to replace knock sensors been getting a code p0327 and since i'm taking the intake manifold off figured might as well upgrade it
car currently has LG Lt's, cat'ed X, Vera ram, tune and soon Billy Boat axle back
future plans are heads and cam hope to be around 450 +/- rwhp just a nice daily not a track beast or any thing like that so witch intake would be the best to go with is a ported 92 enough or should I just shoot for the 102?
thanks
thanks
from what i'm reading the 102 is tuff to dial in for most tuners
when swapping to the fast intake do i need any extra parts or just the intake?
From: Wylie TX --> Less is More, except under the hood !
Just my experience....
I heard that too many folks were having issues with clearance on the FAST102's on C5's.
I did NOT want to chance that I would be one of the ones with clearance issues.
I was planning to install mine in my garage myself.
Read this post..
http://forums.corvetteforum.com/c5-t...102-on-c5.html
I chose to just go with the FAST92 since it was plug and play.
Here are my results with my ported Fast92, and ported LS2 TB.
Toque
Read this post..
Toque
Read this post..
Toque
Read this post..
Toque
what was the reason for the LS2 TB? nice gains btw!
LS1/LS6 78mm TB will not mount on a Fast 92 or 102 manifold.
Manifolds are 4 bolts to mount. LS1/LS6 TBs are 3 bolts to mount.
Your better off putting on the 90mm LS2 on anyway for better flow.
Toque
I agree that the Fast 92 is sufficient for a stock cubed car. And with the fitment issues that have been reported with the 102 I'd go with the 92. Since I have the 102 on my stock cubed car already and it clears the cowl and I don't have any issues with it.
The driveability issue that people talk about with the 102 stuff is from the TB not the manifold but put a smaller LS2 TB on it and no issues. That is what my tuner has told me and I do trust him so that is exactly what I am doing.
With a Fast 4 bolt manifold installed the only thing that you will need to make it work in your C5 Corvette is an electrical harness that you use on your throttle body instead of the stock connector.
Google "casper electronics throttle body adapter" its a plug and play type deal
Yes.. .
See my FULL procedure on my web site with parts listed...
www.ToqueZ06.com
look in section "Fast 92 intake, and LS2 Throttle Body Install Procedure:"
Casper Electronics (PN 108115)
www.ToqueZ06.com
I'm sure it will vary depending on other mods you have on the car.
5-10 maybe I heard.
Aside from the clearance issues seen on a lot of cars... there are also added costs too.
For one you need a different fuel rail setup.
The LS1/LS6 fuel rail will not fit the 102mm. (From what I read somewhere).
I have also heard that there are clearance issues with the 102 TB's.
I think it was hitting the water pump or something ?
I don't remember all the specifics...
For "me" it was not worth all the trouble going with the 102.
I kept reading folks that were struggling with the install.
I'm just trying to lay out all the issues I read a few years ago so that the OP can make an informed decision.
Toque
thanks for all the input every one
I've read you need to swap the water pump, fuel rails and something else on top of all the fitment issues that's a can of worms I'm not opening for 10 to 15 extra Hp rather try to make it up some place else for the money and hassle
glad i found out about the 102 now i was ready to by one off a local guy today that's a bullet I dodged thanks you u guys
the hunt for a good used 92 and ls2 Tb is on
Yes there are some gains with the 102mm.
5-10 maybe I heard.
Toque
5-10 maybe I heard.
Toque
I know the cost is higher to do the intake + TB + MAF + mounts + fueling, but they all seem like worthwhile upgrades to me. It wouldn't surprise me if you could hit 400+ whp by doing that plus a dyno tune on a stock C5Z.
Hell a nice carbon fiber vented hood with a little extra space for the intake would also be a very worthwhile upgrade both at high speeds and in cornering.
I'm a weirdo focused on lap times though so what do I know!
