C5 hood shocks
Old Aug 21, 2014 | 09:02 PM
CRAZYCOCK's Avatar
CRAZYCOCK
Default C5 hood shocks
Hi, does anyone know where I can get hood shocks for my C5 that have less resistance than my stock shocks? I have a carbon fiber hood and the stock shocks are just too stiff for this hood. Over time the hood will crack due to the resistance when trying to close the hood. I need some shocks with very little resistance or at least less resistance than the stock shocks. Thanks for any info, I really appreciate it!
Old Aug 21, 2014 | 09:17 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Check with Summit Racing, It seems to me I saw some on there.
Old Aug 21, 2014 | 11:42 PM
o2bnkc's Avatar
o2bnkc
Give the guys at www.liftsupportsdepot.com a call. They should be able to help, plus their prices are pretty good.
Old Aug 22, 2014 | 12:00 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
FWIW, I pull my Z16 hood down by the center rather than a corner.
Yes the shocks could be a tad bit lighter, so hopefully you'll post your outcome.
Old Aug 22, 2014 | 12:48 AM
El original's Avatar
El original
Did you check out your local Chevy dealership? They might just stock that part?!
Old Aug 22, 2014 | 12:57 AM
PhysicsDude55's Avatar
PhysicsDude55
Try using a set of Suspa C16-06389 gas springs.
(Amazon link:
Amazon Amazon
They are the same size as the stock gas struts, but should be about half as strong. I couldn't find exact data on how much force the stock struts put out, but these Suspa ones are very weak, I've used them in personal projects holding up ~20lb lids and such. If anything they're too weak for your application.
Hopefully they work out for you.
http://forums.corvetteforum.com/c5-f...od-struts.html
Old Aug 22, 2014 | 10:23 AM
3boystoys's Avatar
3boystoys
I use the stockers on my MCM carbon Fiber hood, what's the problem? Had them on for years now.
To C5 hood shocks
