[Z06] DIY Maintenance Question
Old Aug 24, 2014 | 01:46 PM
Shylor's Avatar
Shylor
Default DIY Maintenance Question
Normally I have done all the maintenance on my vehicles, but recently I had my 2003 Z06 in the dealership for a rear axle leak and let them also change the oil and coolant to save me some time. After paying $290 for an oil and coolant change I realized I should have made the time to do it myself, as I always had before.
Anyway, I also need to flush the brake and clutch fluids. Any suggestions for the easiest way to do this?
Old Aug 24, 2014 | 01:54 PM
john8642's Avatar
john8642
Motive Power Bleeder for brakes;
Amazon.com: Motive Products Power Bleeder - European- Black Label: Automotive Amazon.com: Motive Products Power Bleeder - European- Black Label: Automotive
Ranger clutch fluid flush:
http://www.rangeracceleration.com/Clutch_Care.html
Old Aug 24, 2014 | 02:18 PM
Shylor's Avatar
Shylor
That power bleeder seems expensive at $75. Wouldn't it be just as easy to use Speed Bleeders instead?
Old Aug 24, 2014 | 02:22 PM
aaronc7's Avatar
aaronc7
I do my own maintenance as well. I just recently got the Motive power bleeder. So worth it, should have got one of those a long time ago, especially if you do the work by yourself generally. It's one of those things you can use on any vehicle in the future as well. $75 seems expensive.... says the guy who paid $290 for coolant and oil change.
Old Aug 24, 2014 | 02:26 PM
Shylor's Avatar
Shylor
aaronc7,
Point taken, but I didn't have to do any of the work. As I said before I normally do this stuff myself on all my vehicles. Brake bleeding has always been so time consuming though. Oil changes are usually easy, not so easy on the C5. And certainly coolant flushing is timing consuming.
But how do you get a good flush through the ABS system?
Old Aug 24, 2014 | 02:56 PM
Stroker87's Avatar
Stroker87
brake bleeding made easy!
http://www.amazon.com/Phoenix-Systems-2104-B-Reverse-Bleeder/dp/B00GRV800S/ref=sr_1_2?s=automotive&ie=UTF8&qid=1408906412&sr=1-2&keywords=Phoenix+Systems http://www.amazon.com/Phoenix-Systems-2104-B-Reverse-Bleeder/dp/B00GRV800S/ref=sr_1_2?s=automotive&ie=UTF8&qid=1408906412&sr=1-2&keywords=Phoenix+Systems
this is what i'm looking at getting been hearing good things about it
Old Aug 24, 2014 | 03:36 PM
RockJustBelow's Avatar
RockJustBelow
Originally Posted by john8642
If you don't want to pay for a Motive you can always make one. Here's my homemade bleeder...
http://forums.corvetteforum.com/1572943644-post10.html
Old Aug 24, 2014 | 04:47 PM
john8642's Avatar
john8642
The power bleeder saves you from having to get up and refill the brake reservoir all the time. Only you can decide if it's worth it. The speed bleeders work also, it just takes more time and effort.
Old Aug 24, 2014 | 06:39 PM
aaronc7's Avatar
aaronc7
aaronc7,
A 100% flush is impossible to do I guess without some sort of dealer tool. Some guys say to flush it all, then go out and engage the ABS system a few times to mix it together and get fluid through the ABS part or however it's laid out exactly. That's what I did. I really do enjoy this power bleeder though, it makes 1 man bleeding an easy process. I just top off the reservoir under the hood...put the power bleeder on, crank it up to 10-15psi, then go to appropriate corner....bleed until clear. Refill reservoir, pump up pressure again, and continue on down the line like that. Majority of the work/hassle will be jacking the car up.
Old Aug 24, 2014 | 08:36 PM
Stroker87's Avatar
Stroker87
I thought with that bleeder your suppose to fill it with brake fluid so it keeps the car reservoir filled as you bleed the system?
Old Aug 24, 2014 | 08:48 PM
aaronc7's Avatar
aaronc7
You can run it either way. First time around I just ended up using it for the pressure only. If you run it wet, just make sure to clean it out before you store it away. IMO it was minimal "extra work" to use it dry and then cleanup is nonexistent.
I like that DIY thread above.. really if you have an apparatus that can just pressurize the stock system that's all you really need.
Old Aug 24, 2014 | 09:01 PM
Stroker87's Avatar
Stroker87
i've been reading a lot about the reverse bleeding herd nothing but good about them
either way as long as your getting it done
To DIY Maintenance Question
