From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
For the most part they will fit, The offset on the rear is different and some have had to use 1/4 inch spacer on the rear to keep the inside of the tire from rubbing.
I have c6 base wheels and they seem to sit it a little bit up front. Im thinking about adding a 1/4" or 3/8" spacer so they sit even with my rears (i have a 1" spacer with studs in the rear)
huh odd that some do and some don't, where do u get spacers if needed?
Most Rim shops carry them in stock!! I even went as far at to add Longer studs from Ebay just to be safe. But Every car is different by what type of shocks, Condition & Everything so I'm guessing that's why you just have to mount & See for yourself. They will all Bolt right on without a spacer. But if it's not flush with the Fender it might bother you or it might not. All based on your own personal feelings. Type of tire might have a factor as well to flush or not. So many factors...
