another LMC5 question
Old Aug 31, 2014 | 02:00 PM
yoymon's Avatar
yoymon
Default another LMC5 question
ok I just installed my lmc5, never had a problem but just did it as preventative measure, the colum never locked with key out so I know it had some sort of previous "fix"...anyhow I still have no error messages and everything seems to work well except im hearing a clicking in dash now sounds like something trying to engage or like a timer clickety clickety click ...anyone else hear this after lmc5 install?
Old Aug 31, 2014 | 02:08 PM
Corvette_Ed's Avatar
Corvette_Ed
The relays in the fuse box make a clicking noise. That could be what you're hearing.
Old Aug 31, 2014 | 02:13 PM
yoymon's Avatar
yoymon
no it keeps clicking for like 5 or 6 seconds..sounds like its near key or colum..never did it before, one time it didn't stop at all
Old Aug 31, 2014 | 03:12 PM
yoymon's Avatar
yoymon
vender did respond on a sunday hats off to him for sure, he said the colum lock wires are now disconnected so shouldn't be hearing anything from there, I disconnected battery and rechecked everything, upon reconnection of battery sound hasn't come back after 5 tries..i don't know why its gone but it is right now
Old Sep 2, 2014 | 06:48 PM
greenwaltmr's Avatar
greenwaltmr
Cruising
Stupid question but, how do I know if the mod has been installed on my C5? I am not the original owner and the service record does not show a recall repair on it.
Old Sep 2, 2014 | 07:13 PM
bjones7131's Avatar
bjones7131
Greenwaltmr, just see if u can turn your steering wheel with the car sitting still and not running. IF the mod is on the car the wheel cannot lock at any time. This is what it is designed for to be able to enable the wheel from locking period. It install in the passenger footwell area, 30 minute job. Almost forget if U have an automatic trans. U don't have to worry with this mod it doesn't affect your vette.
Old Sep 2, 2014 | 08:09 PM
greenwaltmr
Cruising
Thanks. It's standard so I will check.
Old Sep 3, 2014 | 07:07 AM
Koufax's Avatar
Koufax
Not sure this is correct. I believe that the wheel will turn without locking if the GM recall has been done. That's the way my car was. I installed LMC5 anyway.
My 30 minute job took 4 hours. Bad luck, for sure, but be prepared for bumps along the way that might or might not happen.
Old Sep 3, 2014 | 08:49 AM
bjones7131's Avatar
bjones7131
My 2001 6speed had the recall done in 2006 and the wheel would lock as originally designed but when I put the LMC5 mod on it would not lock, U could turn the wheel even with the car sitting and not running. I will defer to 8vette7, he is the most knowledgable guy on the forum about this issue.
To another LMC5 question
