I check my codes as suggested by a couple of you guys. No earth shaking discoveries, but I do have to questions. First code B0026H I can't seem to find what this one means. Second, c1226h says LF excessive wheel speed variation, not sure what that means.
If anyone can ahead some light on these I would greatly appreciate it.
B0026 is an air bag related issue. Unless your airbag light on the dash is illuminated it probably is no longer a significant DTC.
Have you tried clearing all the codes, then take the car for a nice ride and when you return pull the codes BEFORE you shut off the ignition. Need to press reset to clear anything displayed in the DIC when you pull codes with the engine running.
Codes that come back are the ones you need to be concerned with.
I cleared all the codes in the dic. Tomorrow I'm going to give that a try. Everything had an "h" after it which I understand as being old.
