won't start
Old Sep 7, 2014 | 03:53 PM
jiujitsu77's Avatar
jiujitsu77
Default won't start
My 03 coupe won't start. It turns over but it won't fire up. Could it be the fuel filter clogged up or maybe the fuel pump? Can I pull the air filter off and spray starter fluid in the throttle body? Will I mess up some thing if I do this? Please help
Old Sep 7, 2014 | 04:37 PM
Why don't you try pulling the codes on the DIC first and see if anything shows up there.
Old Sep 7, 2014 | 05:02 PM
jiujitsu77's Avatar
jiujitsu77
There r no codes for the pcm
Old Sep 7, 2014 | 10:14 PM
rrichar2591's Avatar
rrichar2591
I'm not a believer in spraying starter fluid until I know what the cause of the problem is. Someone will probably be able to get you started on finding the cause. Do I understand in your answer above that there are not any codes showing on the DIC?
Old Sep 7, 2014 | 10:21 PM
c6miller's Avatar
c6miller
If there are no codes, try to charge the battery, it may be weak. Disconnect then reconnect the battery cables.
Old Sep 8, 2014 | 11:43 AM
jiujitsu77's Avatar
jiujitsu77
i just looked up the codes on the DIC. the battery is fine. i did drain it down due to trying to start is over and over. i put the battery on the charger and its fully charged now. yesterday i went to start it and it wouldnt at first. i tried a 2nd time and it fired right up. i went to the mall and when i got back in it it fired up again but died after about 5 min of idling. after that it wouldnt fire up again. im not an expert but it seems to me like its not getting fuel. do the fuel pump just crap out at once or do they slowly go out. how hard is it to change the pump?
Old Sep 8, 2014 | 03:44 PM
jim993's Avatar
jim993
If the fuel pressure is OK and you still have a crank, no start, your prior symptoms include those that appear with an ignition switch going bad.
Old Sep 9, 2014 | 08:13 AM
NOLAVette's Avatar
NOLAVette
That's what I'm thinking.
Old Sep 9, 2014 | 11:38 AM
dadaroo's Avatar
dadaroo
Please pull your codes again in case something is there. Don't assume something else could not have cropped up. You know the saying "when it rains it pours".
PS: Ignition switch is a strong possibility. I have the info at home for diagnostics I can post if you want to pursue. You just need to be able to use a voltmeter and we'll do some voltage checks at the fuses that the switch feeds.
Old Sep 9, 2014 | 11:57 AM
Chicago1's Avatar
Chicago1
I dought you have 0 codes when you scrolled through everything. Do you know how to? Why would you throw parts at something without a proper diagnostic?
To won't start
