[Z06] Help!..notchy shifter causing problems on track
As you know tracking the car is your brain doing many things at once and if I miss my shift point it throws off my whole handling of a turn.
I bought it used and it has this shifter in it. RSD Snapshifter short throw. Now I think this could be resolved a bit with the anti-venom mod or something I have seen on these forums before.
So any suggestions? I gotta get this thing to where I am much more easily able to shift into gears.
THANKS!!
Proper realignment will require you to remove center console, however, if you are cautious and capable of removing your shift **** and boot without tearing it up, you may be able to re-adjust accordingly. If not, removing the center console is not a difficult task. Take your time, and it can all be removed, realigned and reinstalled within an hour.
After 1 washer with the anti venom mod it helped a little but when i went back and added the 2nd washer it just became so sloppy. I ended up selling it and went with an MGW.
Definitely try the anti venom mod first and see how it works out for you.
