[Z06] Problem on head bolt hole , need solution
Final torque number 10 bolt passenger side head bolt.
Stripped the aluminum threads right out..
Removed driver side head at same time in fear the same might have happened when i was driving them in.. Found aluminum break off pieces on threads of the new ARP bolts I was using..
PURCHASED the time sert kit for block hole repair..
Question : if i purchase a 90 degree drill can I repair #10 bolt hole and the lower right bolt hole (driver side) without removing the entire engine? I am down to the block and am held up by potential fire wall/ brake booster issues on the driver side..
Anyone have experience with this issue?
