Crossover pipe repair
Old Sep 17, 2014 | 07:30 PM
Borntorun04/17's Avatar
Borntorun04/17
Default Crossover pipe repair
My car is going into dealer tomorrow for crossover pipe problem (gas leak). A couple questions my car is 04 auto trans I'm told they have drop rear end. If so will car need 4 wheel aligment when year end is dropped. Car has around 15,000 miles on it should I have gas filters replaced that are in tanks? Any thing else I should be aware of or do. Thanks for your responses.
Old Sep 17, 2014 | 08:57 PM
Will be interesting to see what someone who has had the repair done has to say.
Old Sep 18, 2014 | 07:21 AM
Borntorun04/17
No one with 04 A4 had this job done ?
Old Sep 18, 2014 | 09:01 AM
RicardoFors68's Avatar
RicardoFors68
I think a 4 wheel alignment is good insurance against installation malpractice. What does your owner's manual say about fuel filter replacement intervals?
Old Sep 20, 2014 | 12:59 PM
bow tie guy's Avatar
bow tie guy
with 15,000 miles on an 11 year old car I'd be repalcing the internals
I.E. level sensors, pumps, pick up socks, fuel lines etc etc etc
as the labor they are charging you to drop the transaxle dictates do it all while it's out
or you'll pay again when the pumps or fuel sender (level sensor) fails
there were TSB's regarding leaks and level sensors
Old Sep 20, 2014 | 02:22 PM
Voodoo13's Avatar
Voodoo13
Do you mean crossover, like exhaust crossover pipe?
Mine is an 03 vert A4. When I changed my starter this spring I dropped the pipe on the driveway in about 20 minutes laying on my back with the car on jack stands. On a lift it would take half the time. Why remove the transaxle? Am I off base here?
IMHO the dealer will recommend, or perform the work you request to pump up ther service revenue. I have been a victim of that with previous rides. I also am not really a believer in fixing something that works perfectly fine. You are more likely to mess it up than prevent a failure that may not happen. I would recommend you leave well enough alone.
Old Sep 20, 2014 | 02:24 PM
Voodoo13's Avatar
Voodoo13
Never mind - fuel crossover- just hit me when I pressed send.
Old Sep 20, 2014 | 03:40 PM
XX's Avatar
XX
XX
St. Jude Donor '12
Do a search for this, it may or may not be covered. Last I read on it was under 10yrs or 100,000k covered by gm.
NHTSA Item Number: 10034684
Service Bulletin #: TB-10150
Replacement #:
Vehicle/Equipment Make: CHEVROLET
Vehicle/Eqipment Model: CORVETTE
Model Year: 2004
Mfg Component Code: 091100 FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY
Date of Bulletin: 2010-08-01
Date Added: 2011-01-05
Summary: CADILLACCHEVROLET SERVICE CAMPAIGN: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. A FUEL TANK LEAK AT QUICK CONNECTORS THAT ARE USED TO LINK THE LEFT AND RIGHT FUEL TANKS. IF LEAK BECOMES LARGE ENOUGH, A SMALL AMOUNT OF FUEL MAY BE OBSERVED RIPPING ON THE GROUND. CSC LETTER WAS RECEIVED. *PE
Old Sep 25, 2014 | 05:20 PM
Borntorun04/17
Just a update on my car fuel crossover repair was done. Dealer replaced driver side tank ,crossover pipe ,insulator, hose, gasket and some seals. They were able to remove old tank without dropping rear end. My car is a 04 Auto trans. Happy not to have gas smell and very happy I had a extended warranty. My cars vin was in the area for the special warranty for crossover problem ,But that was only for 10 years after in service date. Hope this helps out anyone else with crossover problem.
Old Sep 25, 2014 | 07:07 PM
chassed's Avatar
chassed
I ended up fixing mine my self.
Old Sep 25, 2014 | 07:57 PM
Dave concrete's Avatar
Dave concrete
good to hear they didn't need to drop my tank either. They replaced my fuel pump as well as the crossover etc. It was done thru GM's service bulletin at N/C
Old Sep 25, 2014 | 09:34 PM
chassed's Avatar
chassed
I'm left thinking what REALLY fails.
All I really replaced was the driver auxiliary return tube.
Old Sep 27, 2014 | 11:23 AM
Borntorun04/17
Mine failed in two area's. I'm not sure of proper name of part I think it's called heat connector. Looks like a nut with threaded top located on top of left tank, nut with threaded part looks to be plastic and a cream /yellow color. Plus the seal that was near were hose get connected.
Old Sep 27, 2014 | 11:35 AM
chassed's Avatar
chassed
English?
Old Sep 27, 2014 | 11:42 AM
cor28vettes's Avatar
cor28vettes
Default Congrats
Good for you to post the end result. Too many times people ask for assist but never follow-up with the resolve.
Curious...when was your in-service date?
Old Sep 27, 2014 | 11:53 AM
Borntorun04/17
My cars in service date was 1/27/04 special warranty for crossover problem last for 10 years from service date.
Old Sep 27, 2014 | 12:02 PM
cor28vettes
borntorun captured it.
here's another pic of it
http://forums.corvetteforum.com/g/picture/1265064
The part that fails is called a bung. Bad connector to the fuel tank in the crossover. The bung to which the crossover tube is attached usually cracks. Heard it was from glue that fails to withhold to specs. Me thinks, in addition to the glue factor, it could be from plastic that simply wears down either from pressed in place so long and/or old age.
Anyhoo, 8Vette7 is quite an authority on this issue and has gone to great lengths to help members understand it all... http://forums.corvetteforum.com/show....php?t=2430894 Go to page 1 then to page 33 and work your way back.
To Crossover pipe repair
Old Sep 27, 2014 | 12:06 PM
cor28vettes
So the 10 years was up 1/27/14. How did you get by with a freebee?
Old Sep 27, 2014 | 12:09 PM
Borntorun04/17
I have a extended warranty on car which is good for another three years.
Old Sep 27, 2014 | 12:12 PM
cor28vettes
Did not know GMPP was still active on any C5's. I knew of only one still around but finally expired last Nov.
Good for you. That paid for itself right there.
