Mud flaps
Old Sep 22, 2014 | 09:06 PM
ttiros's Avatar
ttiros
Default Mud flaps
Anyone use mudflaps on their VETTE? Back or both front and back?
Old Sep 22, 2014 | 09:33 PM
I use them on mine. Got a set of the stealth ones from RPI Designs. Cost was about $40, they use existing screws in the front and a combo of existing screws/metal clips in the back (clips do not make contact with any painted surface), and provide pretty decent protection for the side of the car. Mine are both front and back.
Old Sep 23, 2014 | 05:22 AM
ttiros's Avatar
ttiros
Thank you
Old Sep 23, 2014 | 08:00 AM
bpenn8966's Avatar
bpenn8966
I have the RPI C6 Z06 on mine from this thread, front and back:
https://www.corvetteforum.com/forums...our-piece.html
They were a bit pricey but I like the way they look and they provide good protection.
There's a thread here with a cheaper option of buying the actual C6 guards and modifying them to fit, but I just wanted to put them on and be done with it.
https://www.corvetteforum.com/forums...er-guards.html
Overall I'm happy with them.
Old Sep 23, 2014 | 12:03 PM
Cirrus8's Avatar
Cirrus8
I have had to drive a two mile gravel road for several years and have had these rock guards that have protected my car very well. I would recommend them .
Old Sep 24, 2014 | 06:34 PM
ttiros's Avatar
ttiros
Very nice! Thanks
Old Sep 24, 2014 | 06:35 PM
ttiros's Avatar
ttiros
Thank you
Old Sep 24, 2014 | 06:55 PM
aramz06's Avatar
aramz06
Love my mudflaps. Nice touch to a fairly simple body side.
Old Sep 25, 2014 | 02:31 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My Z has a set of these. The fronts have been cracked and ripped from hitting road reflectors and other debris.
Old Sep 25, 2014 | 08:55 AM
ttiros's Avatar
ttiros
nice touch
Old Sep 25, 2014 | 12:49 PM
aramz06's Avatar
aramz06
nice touch
Thanks!
Old Sep 25, 2014 | 01:07 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have a set from Apsis that used existing screws in the front. They are similar to the RPI product. I only installed the fronts. They are black so they blend in with my tires and paint and are unnoticeable. The rears install with clips and double sided 3M tape but I left them off since they would be more noticeable.
Old Sep 26, 2014 | 10:21 AM
dadaroo's Avatar
dadaroo
There is also some clear covering material that can be applied directly to the paint to protect the paint from minor things like sand and grit thrown up but not rocks. 3M makes a spray on that is easily removable and others make some sheet material you can cut and apply. Neither will harm the paint and can be removed.
I have used the sheet material on my Pantera when I went to the dragstrip with slicks.
Old May 28, 2015 | 06:28 PM
jerry1298's Avatar
jerry1298
Default mud flaps
Very nice! Thanks
Love your mud flaps! I drive on a dirt road and paint is damaged. What model and brand did you put on your yellow vette? I love them!
Old May 28, 2015 | 11:03 PM
jdvann's Avatar
jdvann
Love my Stealth splash guards...I have them on both cars. You can hardly see them.
Old May 28, 2015 | 11:30 PM
momo20's Avatar
momo20
i just got a set that i am fitting which are the c6 z06 splash guards front and rear to my c5 z06
Old May 29, 2015 | 09:35 AM
gulfstrings's Avatar
gulfstrings
Did you place any kind of "protection" between the guards and painted surfaces?
I'm installing same guards this week and a little concerned some paint damage could occur.
Thanks..
To Mud flaps
Old May 29, 2015 | 09:40 AM
Sox-Fan's Avatar
Sox-Fan
Are they pretty? no. Do they protect the paint? Absolutely.
Old May 29, 2015 | 10:47 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I call mine Splash Guards. Have had Apsis on the rear for many yrs now & just got a set for the front & like them a lot. Left them the stock black color but have seen them painted to match the body color which looks very nice. Apsis might be pricy but IMO they are worth it.
Old May 29, 2015 | 10:59 AM
jdvann's Avatar
jdvann
Thanks..
I didn't add anything to them and when I clean in that area I have not noticed any changes. I caused a slight scratch in an area when I mounted them which is not visible after installation and I recently checked and it's still there! I have had them on for over a year and they have saved my quarters from any additional rock/sand damage.
