Headlight noise
Old Sep 23, 2014 | 11:00 PM
Kreeess's Avatar
Kreeess
Default Headlight noise
Hey guys, my headlight recently started making this grinding noise when I turn off the light, it eventually goes away so I'm guessing it's the motor going bad? Can u guys help me out on what to do to fix it? Thanks!
Old Sep 24, 2014 | 12:11 AM
Kreeess's Avatar
Kreeess
Originally Posted by 8VETTE7
Plastic gears inside the motor are failing. You are going to need to replace the gears. The early year cars are easy to replace the gears because there are screws that hold the halves of the motor together. You can get a brass replacement gear kit from this source: http://rodneydickman.com/catalog/ind...07b3785bb1376c If one side is failing, it is simply a matter of time until the other side fails so get a kit for each headlight.
Thanks for this I will def look in to this, is there a how to on switching out the gears? It's starting to really get annoying when I turn off the headlight lol
Old Sep 24, 2014 | 07:36 AM
runner140*'s Avatar
runner140*
The rodneydickman kit is as complete as possible. It contains everything including a step by step instructions with pictures.
Old Sep 24, 2014 | 10:14 AM
Kreeess's Avatar
Kreeess
Thank you I will get this Done this weekend !
To Headlight noise
