transmission flush
Old Sep 25, 2014 | 07:29 AM
cessna10's Avatar
cessna10
cesssna10
Default transmission flush
My 2003 has 32000 miles. I have to take to the dealer\
for a repair. I assume the transmission has never been flushed.
Should I consider it now or wait until 50,000 which will be in 2017?
It is an automatic.
Old Sep 25, 2014 | 09:39 AM
SG Lou's Avatar
SG Lou
Read This : https://www.corvetteforum.com/forums...id-change.html
Old Sep 25, 2014 | 11:03 AM
dadaroo's Avatar
dadaroo
Flushing can get you a good thorough replacement of fluid. If you have them do that then request they also replace the filter as part of the service. Will cost a little more but I recommend you do it.
Old Sep 27, 2014 | 12:59 AM
American Heritage's Avatar
American Heritage
Supporting Vendor
Drain/pump out fluid, change filter and refill.
Old Sep 27, 2014 | 01:04 AM
Rick369's Avatar
Rick369
I agree. Drop AT pan, let fluid drain, replace filter, clean inside of pan, put on new pan gasket and refill using the proper filling procedure. I wouldn't have the AT flushed.
To transmission flush
