[Z06] skip shift eliminator
It's possible the CAGS defeat is faulty .. if it doesn't present the correct resistance to the computer, it will throw a code .. just like it would if you simply disconnected the cable ..
Possibly they could be:
U1064 Loss of Communications with BCM
A0-LDCM - Left Door Control Module
B2282 Battery #1 Fault
B2284 Battery #2 Fault
A1-RDCM - Right Door Control Module
B2283 Battery #1 Fault
B2285 Battery #2 Fault
From reference material
"CIRCUIT DESCRIPTION
Each Door Control Module (LDCM and RDCM) has two main power feeds (high and low), and one main ground. The low power feed (battery 1) is used to provide power for each DCM logic and internal driver operation. The high power feed (battery 2) is used to provide power for systems that draw higher amounts of current (motors, lights etc.). For most functions, each DCM will operate properly when vehicle system voltage is between 9.0-16.0 volts . Each DCM also monitors the voltage level at battery 1 and battery 2 circuits and can determine if the voltage level received is out of range. If the voltage level is out of range in either circuit, then a malfunction is present and a DTC will set.
CONDITIONS FOR SETTING THE DTC
A DCM detects battery 1 voltage range under 8.5 volts or over 16.3 volts .
Condition must be present for 2 seconds .
ACTION TAKEN WHEN THE DTC SETS
Stores a history DTC B2282, B2283, B2284 or B2285 in a DCM memory.
These DTCs can only be set as a history code even if the malfunction is current.
No driver warning message will be displayed for this DTC."
None of those codes are related to the skip shift bypass.The codes you show are Left and right Door Control Module faults.The U1064 is Loss of Communication with BCM. Here is link of codes.Do a google search for each code and you should find some info on a solution.http://www.stengel.net/diccodes.htm
