TB Gasket?
Old Oct 1, 2014 | 12:55 PM
Corvette_Ed's Avatar
Corvette_Ed
Default TB Gasket?
I'm planning on pulling my TB off next week so I can clean the oxidization off of the outside casing so it will look new again. Is there a gasket or some other sort of seal between it and the intake that I need to replace if I pull it off?
My coupe is my only car so I have to have the parts in hand before I start tearing things apart. Thanks!
Old Oct 1, 2014 | 01:39 PM
StingrayRebel's Avatar
StingrayRebel
there is a gasket, it's only a few bucks... you may not even have to replace it, as long as it isn't smashed completely flat and is still raised off the surface of the intake snout then I wouldn't worry about it
Old Oct 1, 2014 | 01:50 PM
Corvette_Ed
If it's only a few bucks I'll just go ahead and replace it. It's probably the original one, which is 15 years old and has near 100k miles of use.
Thank you.
Old Oct 1, 2014 | 01:59 PM
zachaeous's Avatar
zachaeous
Default tb seal
I just finished changing the check valve on the rear of the engine on my 2001 coupe, I had the intake off and elected to change the throttle body gasket at the same time. Here is the gm part #12552542 seal. List price at gm dealer was $18.43 but I did get it for less. Hope this helps you.
Vincent
Old Oct 1, 2014 | 02:05 PM
Corvette_Ed
Vincent
Thank you; I found one at O'Reilly Auto Parts for $9.99 so I'll probably just pick that up along with a Torx security bit.
To TB Gasket?
