[Z06] Dreaded yellow springs..
Old Oct 11, 2014 | 04:00 AM
  #41
racebum's Avatar
racebum
Originally Posted by LT-1 kid
you sir are a bonehead
okay
but i was at least smart enough to change my springs
not sure what that says about you or the air force calculator
Old Oct 11, 2014 | 08:43 AM
  #42
LT-1 kid's Avatar
LT-1 kid
Originally Posted by racebum
okay
I am sorry for calling you a bonehead, but I do think the spring issue gets over played
Old Oct 11, 2014 | 10:21 AM
  #43
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Originally Posted by z06scentair
Believe what you want or who you want. It's a two hour job and $200 in parts, not worth the chance in my eyes.
It is not a two hour job, and yes I did the job on my low mileage stocker:
https://www.corvetteforum.com/forums...d-springs.html
Someone asked about the tools:
Amazon.com: Lisle 19700 Valve Holder: Automotive Amazon.com: Lisle 19700 Valve Holder: Automotive
Amazon.com: Proform 67605 Valve Spring Compressor: Automotive Amazon.com: Proform 67605 Valve Spring Compressor: Automotive
Old Oct 11, 2014 | 12:25 PM
  #44
z06scentair's Avatar
z06scentair
Ok your correct it's really 1.5 hr job.
Now this is not a two hour job! Nor will it be as cheap!
Brad
Old Oct 11, 2014 | 02:54 PM
  #45
RussBt's Avatar
RussBt
Not even close.
Old Oct 11, 2014 | 03:31 PM
  #46
z06scentair
Not even close.
We can agree to disagree then...
Old Oct 11, 2014 | 06:49 PM
  #47
racebum's Avatar
racebum
Not even close.
i've seen it done in 1.5hrs
but i agree it's not realistic for most everyone to come close to that time
the guy i watched do it was a funny car & pro stock team mechanic, changed them all with an air hose and basically a pry bar
same guy can also do a clutch in a c5 in 4-5hrs
kind of amazing watching the guy work, he never makes mistakes and it's almost harmonious how efficient he is
Old Oct 11, 2014 | 07:27 PM
  #48
RC000E's Avatar
RC000E
if you have sex with a girl who has HIV you have a 1/1000 chance of getting it
you want to bone some girl bare with HIV?
I mean, in all fairness to the question, you haven't mentioned how hot this "girl" is...
Old Oct 11, 2014 | 08:22 PM
  #49
RussBt's Avatar
RussBt
It is going to take at least an hour to remove and replace the alternator, coils, wires, and plugs without breaking anything.
Old Oct 11, 2014 | 08:44 PM
  #50
z06scentair
No need to remove the alternator. Remove the air duct and belt, then remove the alternator top bolt and power connection. Simple roll the alternator toward the drivers side fender liner.
The steps you foremention can be completed in 15 minutes.
Brad
Old Oct 11, 2014 | 10:19 PM
  #51
racebum's Avatar
racebum
you have a point right there
Old Oct 12, 2014 | 11:14 PM
  #52
ATLFerg's Avatar
ATLFerg
I got a quote for about $470 parts and labor from a performance LS shop. Springs, seals, and gaskets. Might be a stupid question but I have an 03Z but how do I tell if my springs are yellow without opening the engine up? Last 5 of vin are 12926.
Old Oct 13, 2014 | 01:07 AM
  #53
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Open your oil filler cap and look inside. You should be able to see at least one spring and see its color.
Old Oct 13, 2014 | 12:22 PM
  #54
jac1979's Avatar
jac1979
Wish I would have swapped mine out, but I really didn't know anything about it until it was too late. Dropped the valve and there was a nice hole in the piston. It's a really easy thing to do if you just have to change the valve springs 1.5-2 hours is a good estimate. But I probably worked on it on and off for a week to get it back up and going once I figured out it was a broken valve spring. I even took it to the dealer and they told me it was a bad fuel pump, because the engine would barely run. That was the last time I took my car for anything other than tires or a wheel alignment.
Old Oct 13, 2014 | 01:25 PM
  #55
4drturbo's Avatar
4drturbo
I tried that, couldn't see it. Maybe I need a more powerful light. Going to have them replace the pushrods too. First I gotta order all the parts. Anyone know of a good websites that sell GM parts cheap with shipping?
Old Oct 13, 2014 | 03:12 PM
  #56
racebum's Avatar
racebum
summit racing has most gm parts available if you have part numbers
pace performance and scoggin dickey are also gm dealers and priced pretty reasonable
what's wrong with your pushrods btw? that's normally something that goes a LOT of miles
Old Oct 13, 2014 | 05:09 PM
  #57
z06scentair
Im with BoneHead....lol j/k, had to do it!
Really no reason for replacing pushrods.
To Dreaded yellow springs..
Old Oct 13, 2014 | 05:13 PM
  #58
z06scentair
Sorry to hear this, it sure does aide in those riding the fence to hear stories of such.
Did this dropped valve destroy the block as well? These types of failures typically result in blocks too.
Old Oct 13, 2014 | 08:59 PM
  #59
jac1979's Avatar
jac1979
Actually it didn't. Was pulling into the driveway when it happened aka I wasn't beating on it. Probably would have destroyed the block otherwise. I think it was an exhaust valve that the spring broke on so it damaged the intake valve and I took the head to a machine shop to replace the valve seats because they were nicked.
I dropped the front cross member and took the oil pan off so I could change the one piston without removing the engine.
Here's the thread pic of the damaged piston at the end.
https://www.corvetteforum.com/forums...ts-runs-3.html
Old Oct 13, 2014 | 11:30 PM
  #60
GenerationX1's Avatar
GenerationX1
I have a very early build of 9/01 on my 02 C5 Z06 and my springs are yellow. I'm at 58k.
