Engine hardly starts/runs
Goes the scanner that you use have the capability of data logging?? Lucky is correct. Data logging will easily pin point the issue.
BC
SDM U1016H
LDCM U1016H, U1096H
RDCM U1016H
RFA U1096H, U1016H
I am unaware if the dealer did any kind of diagnostic to verify the functionablity of them. Does anyone rent out tech II scanners? Or I would buy a scanner but I would like to get something that has good capabilities. Can you recommend any scanners?
No I didn't verify the repairs to the CKP with a DMM. I didn't have the service manuals with the connector pin wire routing at the time. But now that I have the manuals that probably isn't a bad idea.
http://www.amazon.com/Actron-CP9180-.../dp/B000KG8KB0
Just google it and you will find tons of people selling it. It test and scans a lot of sensors including LTFT and O2 sensors.
Something is going on with all those U series DTCs. Are you SURE that the door wiring harnesses are not causing an issue. Do your doors function properly (windows, lock and lights)????
Try removing the top of the STAR connector for the doors and seats. Look in the passengers foot well and to the left of the BCM. You will see TWO thin Grey connectors:
The one with FOUR wires id the one you need to disconnect. Once the top of the connector is removed, try to start the engine.
BC
That may be an issue if there is a module voltage issue. When the battery is LOW, the modules time out and if they come on like in the middle of some other modules reporting period, yep, that would be an issue.
The U series DTCs that the OP is seeing is not normal and has something to do OR is a result of the issue. I have Memory set on my car and NEVER EVER see U codes on a routine basis. Sure, there will be some when the car sits for an extended period of time and the battery is LOW charged. Under normal operating conditions, good battery, there shouldn't be any DTCs
Another theory (and I hate to just always blame something) is the ignition switch is dirty/burnt contacts and some of the modules are having "HOT in Start & Run" voltage issues. Its easy for me to check for this BUT,,,,,,some people have electronics-phobia and don't like to probe around on the fuses that supply that voltage. Hell, is easer for some to just rebuild the switch and call it a day.
Until he ISOLATES those modules on the serial buss, the juroy is still out on that prospect.
If you remotely suspect that your having a ignition switch issue,,,heres a post for YOU!
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
PCM P0102HC (because I took the air duct off to look at the throttle body during start-up)
BCM B2587H,B2592H
HVAC U1160HC
I also watched the throttle body valve during start up and when the engine is running in this poor condition. The valve opens about 1/4"...is this normal or should it be opening more at idle?
I'm thinking the PCM may be my problem.
Check ALL of the PCM fuses and make sure you have FULL Battery voltage on ALL of the fuses. There are TWO small openings on top os all the fuses. Those are test points that you can use to test the fuse with a volt meter.
HOT AT ALL TIMES
PCM-B Minifuse #23
Hot in On and Start
PCM Minifuse #16
This is from the 98 service manual so the numbers may be different but the fuse names are always the same.
BC
I checked to make sure the PCM was getting the full battery voltage at circuit 340 going into the blue connector of the PCM immediatly prior to the blue connector...and it is. So I'm thinking this eliminates the chance of something being wrong with the ignition switch as far as for purposed of voltage supply to the pcm. Also checked the ground for the PCM which is above the starter in the engine block. It looks clean and is tight.
Bill I checked both of those fuses and they are both good. And sorry for the confussion in my previous posts, I was thinking that the low voltage line would send 5 volts when the engine wasn't running.
I have also replaced the CKP sensor and the CKP sensor as it wasn't connecting tightly. Both of which did not solve the problem. I bought a new PCM for $112 just need to get it reflashed. Hopefully that fixes the problem. Any thoughts on if my thinking is accurate?
The fried wires on the CKP sensor led me to believe it was a timing issue. I was in the process of checking the CMP sensor when I saw a broken valve stem and realized I had major issues.
I'm thinking it's a problem related to bad valve springs in 2002 LS6's that I have read about on this forum.
I just want to know how the heck the dealer every came up with the idea that the fuel pump was bad. What are the chances that the fuel pump and a valve spring and goes through the cylinder all at the same time???
Has anyone ever changed a piston from the lower end with the engine still in the car. It looks like it is possible if you take the front cross member out to remove the oil pan according to the service manual. But is it easier to do it that way or pull the motor?
