Hot Console
Old Oct 3, 2014 | 06:54 PM
Jimmy3795's Avatar
Jimmy3795
5th Gear
Default Hot Console
Just bought 2003 50th Anniversary Edition last week was driving around and the The console got very warm, is it anything to be concerned about or just the normal transmission heat. Glasses were in the console and were almost to warm to put on. All gauges seemed normal
Old Oct 3, 2014 | 07:00 PM
reath1's Avatar
reath1
Perfectly normal. Good? No. Normal? Yes.
Old Oct 3, 2014 | 07:01 PM
Corvette_Ed's Avatar
Corvette_Ed
That's normal. You can mitigate the heat by installing sound/heat insulation under the carpet, and/or an insulated tunnel plate. What you're feeling is the heat from the torque tube that radiates through the flooring.
Old Oct 3, 2014 | 07:02 PM
scarecrowkc5's Avatar
scarecrowkc5
If you do it right you can warm up your lunch in there.
Old Oct 3, 2014 | 07:07 PM
with Corvette_Ed. Corvettes have always had quite a bit of heat from the console area (especially in earlier models where the tranny was up front). Installing some insulation material will certainly help keep the heat down in the cabin.
Old Oct 3, 2014 | 07:24 PM
El original's Avatar
El original
The tranny up front on earlier models...? I am not aware the C5 had any other tranny configuration other than a trans/axel setup. What gives? I must have a later model with the tranny and rear axel setup and the console gets somewhat warm but never hot.
Old Oct 3, 2014 | 07:29 PM
reath1's Avatar
reath1
And to add to this thread for the OP and others, I added a full layer of Rammat sound deadener and a good layer of closed cell ensolite under my console the full length of the tunnel. The entire car to be exact as you can see in my stereo build thread, and this only cut down on the console heat very slightly. I think the best bet, though no experience, would be to install the "bubble foil" stuff that Marc with vettenuts sells.
Old Oct 3, 2014 | 07:58 PM
scarecrowkc5
Uh ... the exhaust pipes might have something to do with it.
Just sayin'.
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
I installed a heat insulation/sound deadening material, under the console and under carpet in the entire interior long ago.
Significant reduction in heat inside the cabin, as well as reduction of road noise.
Marc at Vettnuts has these kits (he installed mine), and I think recently he had a sale on them. He is a forum vendor, and you could look into it, or call him.
It's a mod, that will never wear out. I think a good investment.
Don
Old Oct 3, 2014 | 08:05 PM
reath1's Avatar
reath1
Just sayin'.
And all along I thought it was caused by those damn solar flares...
Old Oct 3, 2014 | 10:32 PM
scarecrowkc5
It's street heat.
I burn up the road when I roll.
Old Oct 4, 2014 | 05:17 AM
SG Lou's Avatar
SG Lou
I went this route as well and noticed a considerably difference in the heat !
Insulated Tunnel Plate has got my vote !
Old Oct 4, 2014 | 09:22 AM
Marc@Vettenuts.net's Avatar
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
We have our insulation kits on sale located here: https://www.corvetteforum.com/forums...irst-10-a.html
Pictures of the kit installed in a C5 vert are below.
Old Oct 4, 2014 | 09:41 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Check this thread. Just ordered mine. Good reviews.
https://www.corvetteforum.com/forums...insulator.html
Old Oct 4, 2014 | 09:50 AM
TX Torch's Avatar
TX Torch
St. Jude Donor '13-'14-'15-'16, '25
It's global warming.
Old Oct 4, 2014 | 10:18 AM
Marc@Vettenuts.net
Supporting Vendor
St. Jude Donor '11
You can order our complete kit for $145 shipped versus $33.90 plus shipping for the other company's center console section only.
Old Oct 4, 2014 | 10:27 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I installed a heat/sound deadening system as well as a thermal tunnel plate. It really cut down on the noise and heat. There is also a vendor who sells a thermal cut out that you can install in your center console.
I remember after I first bought my C5. I filled up at a gas station and bought a bag of M&Ms and placed them in the center console. When I got home, they had all completely melted. 😧
Old Oct 6, 2014 | 04:40 PM
tgucc's Avatar
tgucc
I installed an .25" aluminum tunnel plate. Cut down console heat significantly. You don't need to insulate aluminum tunnel plates. That actually makes it worse as aluminum is a great heat spreader. If you insulate the aluminum it doesn't spread the heat. The tunnel also has holes in the front and back which again makes insulating the plate a waste of time.
To Hot Console
