Leaky butt
Old Oct 8, 2014 | 08:05 AM
Dave 127's Avatar
Dave 127
Default Leaky butt
Hi, I have a 2004 vett for years I have Had a Leak on the left axle seal, I was given prices from the dealer for hundreds of dollars ,all i did was replace the rubber disc on the vent, made it from a new tire patch. Leak fixed .I have not seen a drop of oil in 1 1/2 years. pry off the top of the vent with a flat head screw driver,you will find a light spring and the rubber disc about the size of a dime. only problem i had I was on my back in my driveway ,I had to do it all by feel i couldn't see,may be a lift would work better.good luck
Old Oct 8, 2014 | 11:06 AM
Thanks for the tip. Saved this info for future reference.
Old Oct 8, 2014 | 11:33 AM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Good tip and great as long as that was the source of your leak. I wasn't as lucky. Leaking between trans and diff as well as axle seals. Not fixing that one with a tire patch.
Old Oct 8, 2014 | 12:04 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Every once in a while I get some small droplets of oil on my butt..... ....Nobody can find out where it's coming from. I would think it safe to say that maybe this is my problem as well. Can't see anything on the rear diff but I haven't been under the car for a while. I'm going to check this out. Thanks for the tip.
Old Oct 8, 2014 | 03:51 PM
robert miller's Avatar
robert miller
Dealer told me the same but mine was under war. But also was told by dealer the 04 was bad for this problem.
To Leaky butt
