A-Pillar Ground
How EXACTLY do you get to this ground? Anyone have some step-by-step instructions?
But to get at it, to really un do it and clean it; you have to take out the left drivers side kick panel (by your left foot).
Then, you have access to it with a socket and extensions.
You need a good strong back to lay in there, to see and get at it.
Makes my back hurt, just thinking about it.....
That was the hardest ground to get at, when we sought to clean all mine, a while back. Hard because of the awkward way you have to lay, under the dash, turned towards the kick panel.... But, doable with a little patience, and ibuprofen....
Don
then, a couple of torx head screws, then remove the cover for the hood release latch/lever.
i think one torx head screw in behind that cover.
then finally the kick panel just 'slides up'.
