chirping
Old Oct 20, 2014 | 11:13 PM
J Thorpe's Avatar
J Thorpe
5th Gear
Default chirping
Old subject, new question. 2001 C5, new serpentine belt 3 weeks ago, new plugs, wires. Chirping, front of engine (loud) begins 30 sec after start-up and goes away completely after 10-15 minutes of driving. Can't locate very well. Goes away with taking primary serpentine belt off. If it was a pulley or alternator, why would it go away after warm up? Though those are obvious culprits. Pulleys run smooth and alternater drive smooth and silent without belt.
Thanks for any advice!
Old Oct 21, 2014 | 10:13 AM
JR-01's Avatar
JR-01
http://www.cartechbooks.com/techtips/serpbelt/
Old Oct 21, 2014 | 11:35 AM
Stroker87's Avatar
Stroker87
I had the same thing with the A/c belt after I replaced it, I replace the pulley and tensioner next and it stopped......
Old Oct 21, 2014 | 12:52 PM
seu318's Avatar
seu318
Same here. A/C belt and tensioner did the trick.
Old Oct 21, 2014 | 04:51 PM
FASN8N's Avatar
FASN8N
1st Gear
Originally Posted by 8VETTE7
With the engine running watch the groves on the harmonic balancer. Do they track straight? Harmonic balancer failure is NOT a stranger to the C5. As the balancer "wobbles" the belt does not track true with the other pulleys.
Have you manually turned the tensioner pulley? Does the pulley roll smoothly on the bearings? Tensioner pulley failure is also no stranger to the C5.
Same here...belt was replaced early summer. I watched the harmonic, didn't see any wobbling. Alignment looked good. I just put some soap on it and the noise went away. I am taking it to my vette shop soon.
Old Oct 21, 2014 | 06:32 PM
J Thorpe's Avatar
J Thorpe
5th Gear
Thank you---great stuff!
J
Old Oct 21, 2014 | 06:35 PM
J Thorpe's Avatar
J Thorpe
5th Gear
Tensioner pulley appears straight and runs smoothly manually. Harmonic balancer also appears straight and smooth. As per other comments, one of the pullies is almost surely the culprit.
Thank you!
J
Old Oct 21, 2014 | 07:47 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
I had chirping of the top belt so replaced the belt and tensioner. Then the bottom (AC) belt chirped worse.
Replaced the belts, both tensioners, water pump.....end of chirping....for a while. Crank pulley/balancer is intact and not wobbling....but a little rough.
Next chirping was due to coolant leaking onto it from radiator expansion tank leak....fixed......no chirping for awhile.
When it came back, my guy (vette guru in this area) put some RTV silicone on the belts.......been fine since, even after a 1300 mile road trip!
Weird....but it worked.
Old Oct 22, 2014 | 08:55 AM
Fast one's Avatar
Fast one
It goes away because the surface rust on the cheap GM damper is worn off by the belt only to return the next day. An aluminum damper won't do this.
Old Oct 22, 2014 | 07:43 PM
jthiesen1169's Avatar
jthiesen1169
I had the same issue, only mine would get worse as the car heated up. Wound up replacing ALL the pulleys on both belts and also tried a new serpentine belt and it still came back. I then switched out both belts to the Goodyear Gatorback Poly-V belt and it's completely gone and hasn't returned. A lot of the C5 owners claim that the Goodyear belts are the only ones that don't chirp.
Old Oct 22, 2014 | 10:32 PM
Russell Boulding's Avatar
Russell Boulding
At my shop we see a lot of this. I tackle it like this. First watch the balancer. Specifically, look to see if it moves the belt. If the belt moves even a little. Replace the balancer. It is most likely the noise and is only going to get worse. Second, take off the primary belt and run it. You already did that so you know it is on the primary. Once, I know which belt it is and that it isn't the balancer the next step is installing a goodyear gatorback belt. Almost all of the belt chirps we fix are fixed with either a gatorback belt or a balancer. I won't use any other belt even in a pinch. If that doesn't fix it I take a spray bottle of water and lightly spray the belt as it runs into each pulley. When you spray the pulley that is responsible for the noise it will either get much louder or most likely stop all together. Spray lightly. If you soak the belt it will stop the noise no matter where you spray and could be misleading. My money says a Gatorback fixes it. But, if not happy hunting.
Old Oct 23, 2014 | 09:19 AM
J Thorpe's Avatar
J Thorpe
5th Gear
I'm getting the message about 'Gatorbacks'---will sure give it a try. Went to Autozone and "they no longer stock them". Whatever, will go to Amazon or a Goodyear store. Great advice! Thanks Again!
J
Old Oct 23, 2014 | 09:24 AM
J Thorpe's Avatar
J Thorpe
5th Gear
Thanks for a great 'diagnostic path'! I'm hearing Gatorbacks from several sources, so guess I better listen! Will also go back and pay better attention to the harmonic balancer. Wish I lived closer to your shop!---Bit of a trek from Washington state!
J
Old Oct 23, 2014 | 05:40 PM
GettnBetter's Avatar
GettnBetter
I've had this chirping problem twice. Both times it was leaking water pump.
To chirping
