Just got rear-ended
Old Oct 25, 2014 | 02:07 PM
Eaglerulez's Avatar
Eaglerulez
Default Just got rear-ended
So I was just driving my Corvette to a nearby trail that I know of to go for a run and I got rear-ended at a stop light. The guy who hit me was just going to take his newborn to the park, so we were both kind of bummed since we were just trying to enjoy a nice Saturday morning.
Anyways I got all of his information and already called insurance.
Damage does not seem to be too bad, just some paint scruffs on my rear end, and the rear body panel makes a slightly cracking sound when I press down on where I got hit (though there are no cracks or dents in the body panel itself)
Definitely not this worst accident to have happen, but is there anything that I should know/do to make sure the car gets repaired properly?
Old Oct 25, 2014 | 02:22 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
First off I would turn it in to his insurance and not yours, He rear ended you and he is at fault. Not sure where you are from, But find a good body shop in your area and they will give it the go over.
Old Oct 25, 2014 | 02:31 PM
Phanni's Avatar
Phanni
If the bumper cover is broken/cracked, I'd request a unprepared replacement piece. They are pretty cheap, and if you're lucky you might find a color match.
Old Oct 25, 2014 | 02:33 PM
Eaglerulez's Avatar
Eaglerulez
I'm from SoCal and insurance recommended Sterling Collision Center in Tustin, Caliber Collision Center in Santa Ana, and Fix Auto in Irvine.
Anyone have any experience with these?
They also said I can go to virtually whatever body shop I want just that the process would require them to bring out someone to get an appraisal.
Old Oct 25, 2014 | 09:07 PM
linz5's Avatar
linz5
Man sorry for the accident. Went through a hit and run situation and the impact was in the same location on my 99 as yours. Mine ended up involving several major parts under the outer panels. I would be sure and have them check the inner tub that is basically a "plastic truck bed" mounted to the rear frame. Mine was easy to verify as damaged because there was plastic debris in my trunk area from the tub. It also involved the impact absorbing "bumper" under the back panel. I was really worried the frame may have been warped also because of the one sided impact. The point I guess is make sure they take a good look and not just call it "cosmetic" damage. My final estimate nearly totaled the old girl. But, having a fair and reputable insurance company got her fixed and she has run great for the past 2 years good as new. Best of luck and be thankful it was not a far worse outcome.
Old Oct 25, 2014 | 09:55 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Something to consider. If you make a claim against his insurance, will it show up on a CARFAX report. I'd get an estimate to repair, then make your decisions armed with that knowledge. If you plan on keeping the Vette a long time, then any comment on CARFAX doesn't matter, but if you're thinking of selling in the next few years, you may want to consider fixing it on your own if its not too expensive and if it will show up on CARFAX if you make a claim.
Old Oct 25, 2014 | 09:58 PM
Find a trusted body shop that will thoroughly go over the car. And keep in mind that even if they check it over closely, there is always the chance that something else may be discovered after they remove some of the panels for repair.
Old Oct 25, 2014 | 10:38 PM
2FAS4UU's Avatar
2FAS4UU
Default Butt Hurt !!
Sorry to see this. If your close to Anaheim, Go talk to Chuck at West Coast Corvette. They know Corvettes in and out, not that I could save you a ton of bucks, tell him Darryl (red 99' FRC) sent you.
Old Oct 26, 2014 | 02:15 AM
striper's Avatar
striper
When you go to a collision shop recommended by your insurance company, in many cases they are not the best shops. They are called direct repair shops and are more concerned with profit and low cost, than doing the best job. You have the right to go where you want and this will allow you to pick the shop that will do the best job. I do work for lots of body shops so I have a fair idea of how some of them operate, including the shops that compete against the direct repair shops.
Old Oct 26, 2014 | 02:24 AM
Eaglerulez's Avatar
Eaglerulez
Thanks for the input. I am probably going to hang on to this car for as long as I live so I don't really mind what is found on a Carfax report, but I totally know where you are coming.
Old Oct 26, 2014 | 02:27 AM
Eaglerulez's Avatar
Eaglerulez
Thanks for the recommendation. I actually work two blocks away from Corvette Mikes, but they don't necessarily do bodywork. Does West Coast Corvette do body work? They are close enough to me too.
I checked their website and I did not see it explicitly listed.
Old Oct 26, 2014 | 02:30 AM
Eaglerulez's Avatar
Eaglerulez
That's good to know. I guess the next question I have is what is a good autobody/repair shop to go to in the Orange County area?
Old Oct 26, 2014 | 08:03 AM
FLZapped's Avatar
FLZapped
I was rear-ended too earlier this year and yeah, it doesn't look bad on the surface, it's when you get that rear cover off that you find the real extent of the damage.
-Bruce
Old Oct 26, 2014 | 07:56 PM
chiefn10's Avatar
chiefn10
I was rear-ended similar to your about 6 months ago. called the kids insurance company, which happened to be the same as mine, and insurance told me to take it to the dealership for estimate and repair. after 5 days in the shop, brand new paint job and no claim against my insurance.
To Just got rear-ended
