battery drain
Old Apr 6, 2015 | 10:02 AM
73Corvette's Avatar
73Corvette
Old Apr 11, 2015 | 10:01 PM
TedMI's Avatar
TedMI
Default Battery drain
Hi Sam,
Got warm again. Hope it stays. So was able to get back to my car. if you remember, few messages ago I told you I pulled all the fuses from the floor box one by one but high amperage never dropped. Now I know why. This time I pulled all the fuses and circuit breakers then I was plugging one by one back in and measuring amperage each time. I found out that there is problem with two circuits – fuse 25 (BCM1 & IPC – have no idea what it is) and 6 (PK T/LP - no idea). Please advise what’s next. If you prefer please call me on 248 933 3959
Old Apr 12, 2015 | 07:58 AM
dadaroo's Avatar
dadaroo
Fuse #25 = BCM Logic Power Feed (Powered all the time)
That is what allows the BCM to be in sleep mode. This is what should cause a 17-22 milliamp current draw.
Pull fuse 6 for the Park lights and leave 25 installed. Tell me what the current draw is.
After that, pull 25 and put 6 back in and tell me what the current draw is
Old Apr 12, 2015 | 10:22 AM
TedMI's Avatar
TedMI
#25 out- 5.1A goes down to 4.2A after 20 sec
#6 out - 12A goes down to 9.2A after 30 sec
Old Apr 25, 2015 | 08:09 AM
dadaroo's Avatar
dadaroo
Just realized you had updated the info. When Fuse 6 is installed ( and 25 is out) do you have any lights on? Try it with 25 installed also.
Old Apr 25, 2015 | 03:33 PM
TedMI's Avatar
TedMI
Default drained battery
6 and 25 in - h/lights, tail, contour, brake, dome on
6 in 25 out - dome out, the rest on
25 in 6 out - contour out, the rest on
6 and 25 out - contour and dome out, the rest on
Old Jul 10, 2015 | 05:12 PM
TedMI's Avatar
TedMI
Default can't get a hold of you
Sam,
for some two months now I keep calling you with now luck. I sent
you amp measurements you requested but since then you haven't visited the thread. Please reply or call me at 248 933 3959
Old Jul 18, 2015 | 09:17 AM
dadaroo's Avatar
dadaroo
Tried to call but it just rang and rang, no voice mail. Not sure why I didn't get your messages. The wife does all that and leaves me a note. Maybe she forgot or somehow it got misplaced.
Anyway, I am going to try and go through everything again and get back up to speed.
Old Jul 19, 2015 | 09:15 AM
dadaroo's Avatar
dadaroo
Tried to return your call this morning but no answer. I have reviewed all the Posts. It would seem to me that you have an issue going on in the Multifunction switch or the BCM.
Clarify what you mean by Contour lights. I also assume by Dome you mean the interior mirror lights?
Old Jul 19, 2015 | 10:14 AM
dadaroo's Avatar
dadaroo
Good to talk to you again this morning. Here is the info on the MF switch replacement.
https://www.corvetteforum.com/forums...-a-how-to.html
Old Jul 19, 2015 | 04:58 PM
TedMI's Avatar
TedMI
Default Bcm
good talking with you too
As I told you I was in a process of removing BCM but I stopped to check current drawn after disconnecting BCM. I charged the battery overnight and got zero draw even with multimeter set on 200mA. Both fuses 6 and 25 were in. So now I have a dilemma should I replace the switch. By the way I think you were referring to the switch on the steering column but how about the one on the knee bolster? Or replace the BCM or put all back together and go to a dealer for a computer test. What do you think?
Thanks again for your help
Old Jul 20, 2015 | 06:19 AM
dadaroo's Avatar
dadaroo
Let me look at the schematics one last time.
Old Jul 20, 2015 | 07:28 AM
  #33
dadaroo's Avatar
dadaroo
Looks like replacing the BCM may resolve everything. Appears it is controlling things when it should not be. I can't explain the MF switch being the significant factor.
Old Jul 21, 2015 | 12:38 AM
  #34
TedMI's Avatar
TedMI
Default Bcm
OK. That's the plan. Thanks a lot
Old Sep 22, 2015 | 09:46 PM
  #35
TedMI's Avatar
TedMI
you are the man. I got the BCM refurbish for $150 and drove my Corvette for the first time today after a long wait. Thanks a lot
Old Sep 23, 2015 | 06:06 AM
  #36
dadaroo's Avatar
dadaroo
Great, who did your refurb work on the BCM?
