reduced power message
Old Nov 3, 2014 | 05:42 PM
MCAF's Avatar
MCAF
Default reduced power message
I have this on the message center of my 2000 vert
It also shows check gages, antilock brakes lite, traction control, and a check engine lites. none of the other gages work if I turn the key on
With the car off, the temp gage reads 260* and the car was only started and idled in the garage. not overheated at all
whats my solution to fix this
Many thanks in advanced
Mike
Old Nov 3, 2014 | 07:12 PM
MCAF's Avatar
MCAF
It won't do that because it says REDUCED ENGINE POWER and will not clear
Mike
Old Nov 3, 2014 | 07:21 PM
MCAF's Avatar
MCAF
This all happened when I was trying to install the Diablosport tune into my car I cannot clear the message Reduced engine power it even shows the message when the car is off and the key is out
Old Nov 3, 2014 | 08:31 PM
MCAF's Avatar
MCAF
Yes I wanted to save that as a last resort.
But that's what worked to clear everything
I hate computers
Mike
Old Nov 3, 2014 | 08:42 PM
Sounds like you got the problem fixed. Interesting that it happened while installing the tune.
Old Nov 4, 2014 | 07:24 AM
innerconx's Avatar
innerconx
St. Jude Donor '15
I hate computers
Mike
Did you update the Diablo before running the out of the box tune?
To reduced power message
