Do you solder or crimp? Why?
Old Nov 4, 2014 | 08:17 PM
Kokopelli's Avatar
Kokopelli
Default Do you solder or crimp? Why?
Need to replace my DRL sockets and was planning on soldering the connections and using heat shrink. A mechanic friend told me it was a bad idea as solder connections tend to fail with vibration and he recommended crimping butt connectors and heat shrink. Not sure I buy this, I've always made solder connections on my boats which have a hell of a lot more vibration at 70mph than my car ever has. Comments?
Old Nov 4, 2014 | 08:20 PM
tcrote5516's Avatar
tcrote5516
I do both, I prefer soder and heat shrink but that's not always an option given location. Bottom line, when done right with heat shrink both types will outlast the components they connect.
Only a poorly sodered connection will vibrate loose. If you get it flowing well between both parts that connection isn't going anywhere. Cold soder joints however can easily fail.
Old Nov 4, 2014 | 08:24 PM
JimInPA's Avatar
JimInPA
Opinions will vary, but I say solder, with an inch or two piece of heat shrink tubing over it for a strain relief. Here is a video I made geared toward car stereo wiring, but works for most wiring.
I usually do not have a lot to contribute when it comes to technical stuff on the C5, but I can help in the electronics area. I am an electronics instructor and a Senior Certified Electronics Technician for 20+ years.
Jim
Old Nov 4, 2014 | 08:45 PM
On the only wiring connections I have messed with, I have done the solder/heat shrink routine. So far, no problems in over a year.
Old Nov 4, 2014 | 09:01 PM
SG Lou's Avatar
SG Lou
How to wire a head unit - car stereo - THE RIGHT WAY! - YouTube
Jim
Nice clean work...sign of a pro !
Old Nov 4, 2014 | 09:04 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I use a neat little connector from the aviation department.
It's a piece of high temp heat shrink tube with a built-in solder ring.
My heat gun has a small adapter that concentrates the heat to both seal and solder the wires simultaneously.
But when conditions warrant, a crimp connector makes installation easy.
racebum's Avatar
racebum
he's full of it, in things that absolutely can not fail all connections are soldered
http://makezine.com/2012/02/28/how-t...asa-standards/
nasa solders everything, look at that link and it gives you a how-to on the absolute most fail safe way to connect two wires
Old Nov 4, 2014 | 10:52 PM
Choreo's Avatar
Choreo
Jim
Great video. Interesting. I have never "pre-tinned" my wires and then touched them together for soldering? I have always twisted the bare wires together, then fluxed, then soldered (i.e. I never really relied on the solder to be the mechanical connection). However, I am no expert.
Old Nov 4, 2014 | 11:53 PM
Voodoo13's Avatar
Voodoo13
Jim
Hi Jim,
Nice video, nice technique, I would agree with you 100%. I was an electrical engineer, still am I guess but now I am in sales
I spent years in marine electronics repairing radar/sonar/ ssb /VHF, even AM Tube radios, and I would agree that is definitely the best way to splice stranded wire.
Old Nov 4, 2014 | 11:59 PM
racebum's Avatar
racebum
Jim
so you're telling people not to do exactly what nasa does on the space shuttle?
i would think that after 20 years you would have watched at least a few tests on soldering failsafes
i mean i do what you do for things like car audio as well, but, that's simply because it's easy and heatshrink forms easy over a straight bond. doing a twisted nasa style wrap and using flux for a penetration catalyst is just by design a more reliable design
Old Nov 5, 2014 | 12:09 AM
PhysicsDude55's Avatar
PhysicsDude55
If I'm building something on a work bench to install somewhere else than I usually solder.
If I'm on my back awkwardly trying to find a hot wire under the dash, I crimp.
Solder is definitely the better way to go, I just don't have that much patience.
I don't really like butt splices, I think they're prone to failure. I steal "Dolphin" connectors from work. They're designed to splice telephone cables. Very fast, versatile, and reliable connectors, but I have never been able to find them at any hardware, electronics, or auto parts store :-(.
Old Nov 5, 2014 | 12:24 AM
Voodoo13's Avatar
Voodoo13
Haha I call those Pigeon Peckers, they are great little things for a quick splice. I prefer solder but those are good too. You can get them pre filled with gel for outdoor applications. I think the blue ones are gel filled and white are not.
If you dont have an account at ADI or Richardsons electronics, you can just go to Amazon, they will have them.
Old Nov 5, 2014 | 12:31 AM
Dcollins3208's Avatar
Dcollins3208
So, let me say this.... Solder/heat shrink is best; however, I crimp more than I should
Old Nov 5, 2014 | 12:50 AM
Z06ster's Avatar
Z06ster
Jim
Jim... this video is awesome... I wish I watched it 5 years ago!!! My installations going forward will benefit.
As for connecting wires together, I am a big fan of soldering. In fact, if I can't do the job myself, I specifically make sure the "professional" is soldering and not crimping.
Old Nov 5, 2014 | 01:33 AM
vpshockwave's Avatar
vpshockwave
I just twist 'em together and put electrical tape on them. Never had a single issue.
Old Nov 5, 2014 | 03:11 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Instead of tape I like using house grade electrical caps like grey, blue, orange, or yellow Marettes to hold the twisted wires together.
Fast, easy, and easy to redo if you want to do it differently.
Can tape over the Marette for a total seal.
Old Nov 5, 2014 | 09:24 AM
sfc rick's Avatar
sfc rick
I'm with all of you who solder....I too solder and heat shrink wrap all my wiring. I'm no electrical wiz but I do know a thing or two about keeping my wiring professional looking. Nothing makes me cringe more than seeing goobered up wiring and electrical tape.
To Do you solder or crimp? Why?
Old Nov 5, 2014 | 03:54 PM
JimInPA's Avatar
JimInPA
No doubt- thats been done thousands, maybe millions of times. We can twist, or wire nut, or crimp, or tape, or solder, or western union splice and solder- they all work. It is just a matter of what will last the longest. Many of these methods will last longer than we own the car, as well as the next owner. It is likely that some discontinued part, high milage, or accident will obsolete our vehicles long before our wired connections will fail. Use whichever method you like- Me personally, I will stick with soldering. It only takes a little longer.
Old Nov 5, 2014 | 05:37 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Not recommended for stranded wires. We are not allowed to use those in commercial speaker installations. the twist on caps break the strands in the wire and can cause failure. They are designed for solid copper connections only.
We either solder, or use use crimp connectors.
Old Nov 5, 2014 | 06:01 PM
Corvette_Ed's Avatar
Corvette_Ed
I have a 12" sub in my car and I play my music loud.
I solder and use heat shrink tubing. Other connections will vibrate loose over time.
