[Z06] P1515???
Old Nov 21, 2014 | 01:36 AM
AirborneZ06's Avatar
AirborneZ06
Default P1515???
Ok im losing my mind trying to figure this out. A little background on the story, I did a Heads (PRC225cc)/CAM (MS3)/Intake (FAST 102). I also did a LS7 TB and got that CASPER wiring harness. I fired up the car and took it for a spin and it went into reduced engine mode and shot a P1516 code. After some research I swapped out the Casper wiring harness for a Katech Wiring Harness and went ahead and swapped out the LS7 TB as well. Now as soon as its WOT it goes into Reduced engine mode and its giving me a P1515 code. Im stumped!! could it be the tune?? Im at a standstill. what do yall think? Thanks for the input gents!
Old Nov 21, 2014 | 03:08 PM
tlove32's Avatar
tlove32
http://engine-codes.com/p1515_chevrolet.html
Make sure you have the correct TB (silver blade NOT GOLD). Some of the new(er) TB's open in the wrong direction and don't work on our cars.
Old Nov 23, 2014 | 06:05 PM
The Highlander's Avatar
The Highlander
So easy to fix.....
Old Nov 23, 2014 | 09:30 PM
AirborneZ06
Originally Posted by The Highlander
So easy to fix.....
But im just an average joe with average research capabilities. Thanks to another member that informed me that the LS7 TB, although the same, opens differently from the LS2 TB and thats my issue. Thanks for you input though.
Old Nov 23, 2014 | 10:54 PM
The Highlander
its programming what you need to do.
To P1515???
