Gas cap malfunction
Old Mar 14, 2013 | 06:16 PM
andynpz's Avatar
andynpz
Default Gas cap malfunction
Thanks to those who offered suggestions to fix a P 0440. Of course, gas cap was the top pick, but I thought it unlikely as I'm aware of the probability of a CEL if not fitted correctly.
So, imagine my surprise when I went to check and the gas cap just fell off. So I pushed it fully and turned clockwise thru several clicks ...... it was still loose and could just be pulled right out.
I suspect some sort of fault with the clutch/ratchet mechanism because I fiddled about with the cap turning the inner center both ways relative to the outer cap and then tried it again on filler and it latched properly with a few clicks. Might squirt a bit of plastic lubricant into the rotating center.
Fixed the code and CEL also
Old Mar 14, 2013 | 07:54 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Had a the same thing happen, just replaced the cap.
Old Mar 14, 2013 | 08:14 PM
Choreo's Avatar
Choreo
Not to hi-jack the thread, but a related question...
I recently started getting a P 0442 and CEL. That also pointed to the Gas Cap as the most likely offender (not hard to imagine after 13 years as a DD!).
I just received a replacement cap today. The web site I ordered it from says it is a Genuine Original GM Replacement. When it arrived it shows to be an AC Delco Part Number 10372242... is that considered an "Original GM Replacement"? Does GM sell a cap that is not AC Delco?
In the photo below you can see the comparison - quite a bit different design, but seems to fit fine. Did I get the right replacement?
Old Mar 14, 2013 | 08:30 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
The replacement cap you got looks just like the one I got from GM. Mine is an 04 so maybe there was a change as the replacement was just like the original on mine.
Old Mar 14, 2013 | 08:56 PM
Choreo's Avatar
Choreo
Thanks... good to know!
Old Mar 14, 2013 | 10:48 PM
Choreo's Avatar
Choreo
Originally Posted by 8VETTE7
I also have an 04 with a replacement cap. Looks like the cap on the right above.....
Hmmm... wonder why most the replacement caps I have seen on the forums are on the '04's?
The replacement I got certainly is less complicated and feels "cheaper" than my original when I lock it down... maybe they switched to a cheaper design in later years and they are not lasting as long?
Old Mar 14, 2013 | 10:58 PM
Good deal that you got the car fixed and nice that it was an inexpensive and simple solution. The forum has helped me out a number of times and saved me a bunch of money.
Old Mar 15, 2013 | 04:03 AM
andynpz's Avatar
andynpz
FWIW - the cap I refer to in the original post is the replacement type - didn't know that until replies were posted.
Old Mar 15, 2013 | 09:23 AM
FNFastZ06's Avatar
FNFastZ06
I have read here on the Forum where some owners with the old style like yours with an O Ring that seals, have used some silicon to repair the O Ring and then wax paper over the seal until the silicon sets. If I had an old style with damaged O Ring, I'd try that for certain..........
This is exactly what I'm doing this weekend. Getting the PO 0440 code and the O ring is visibly cracked in several places. I'll post back results.
Old Mar 15, 2013 | 09:44 AM
bj1k's Avatar
bj1k
I don't want to risk sounding stupid so I won't ask why you don't just find the right size O ring and replace it ? Remember, I didn't ask !
Old Mar 15, 2013 | 10:07 AM
FNFastZ06's Avatar
FNFastZ06
Tried the 2 big box and local marine HW store. No luck, so I'm repairing for time being.
Old Nov 23, 2014 | 05:27 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Thought I would bump this thread instead of starting a new one because I noticed after my last fill up that I could not get my gas cap to twist lock. After seeing this picture, I realized that my 2004 has the cheaper version shown above on the right.
I'm not sure why it stopped working so I guess everything breaks after 10 years despite the low miles. I haven't received any "check engine" alerts and I haven't checked for codes.
My question, are there any better quality alternatives or should I just buy another GM cap and hope it lasts another 10 years?
Old Nov 23, 2014 | 11:37 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Replaced my original gas cap probably 2 years ago with one made by Stant (part #10836). Has worked just fine since.
To Gas cap malfunction
