Suspension puzzler
Old Nov 28, 2014 | 06:01 PM
Stealth02's Avatar
Stealth02
Default Suspension puzzler
Just curious if anyone else has experience this issue. I went and swapped out my stock shocks and sways for the C6 Z06 shocks and sways. Everything bolted up fine. Dropped her back down off the jack stands and noticed my ride hieght in the front had changed. Before the swap I was adjusted all the way down on stock bolts front and rear. Rear is still the same. I drove the car around town and on the highway for a couple hundred miles to see if it would settle out but no change. Now there is a two finger gap between fender and tire on passenger side and three finger on drivers side. Going to get her back up on lift tomorrow and look at adjustment bolts.
