Heat
Old Dec 3, 2014 | 06:24 PM
mwmincey0's Avatar
mwmincey0
1st Gear
Default Heat
I just bought a 2002 Corvette with the dual climate control.I have set the heat at 73 and it is 40's outside.How do you turn the heat on without the AC automatically coming on ? Please someone help me !
Old Dec 3, 2014 | 06:34 PM
mrlmd's Avatar
mrlmd
I'm not in my car now, but if I remember correctly - Hit the lit up AC button on the lower left and the AC will turn off. You should just be able to adjust the temp with the left hand dial (driver's control).
After you set it to the temp you want, hit the set button and that should be it. Somehow you had the AC set to go on.
Do you have the owner's manual?
Old Dec 3, 2014 | 07:24 PM
o2bnkc's Avatar
o2bnkc
It's working correctly. Don't mess with it. If you have an owner's manual, I think it explains it in there.
Old Dec 3, 2014 | 09:10 PM
coia96vette's Avatar
coia96vette
Just turn off the auto function and put the vents on upper and lower. Took me awhile to figure that out when I first got my 04.
Old Dec 3, 2014 | 09:16 PM
Old Dec 4, 2014 | 12:27 AM
Voodoo13's Avatar
Voodoo13
I dont use Auto temp in the winter, I set the temp, and use the mode switch to blow it up on the W/S, vents, lower - wherever I need it. Otherwise I find that it is blowing cold air at me occassionally.
Old Dec 4, 2014 | 04:16 PM
C5Txfan's Avatar
C5Txfan
If you have it on defrost the A/C comes on unless it's below a certain temp outside (don't have manual with me so don't remember). I agree with others - don't use the auto temp.
Old Dec 5, 2014 | 04:01 PM
PhysicsDude55's Avatar
PhysicsDude55
AC comes on automatically when you have the front defroster on. You can't shut it off. It doesn't affect how warm the air is, but I find it annoying because it changes the idle speed and turns on the compressor.
Also something to note is that if you have memory seats, when you save a seat position, it also saves your HVAC settings with it. So if you get in the car and press "1" on the memory seats to put your seat where you like it, it will reset your HVAC to whatever it was when you saved it. I find it quite annoying.
Old Dec 5, 2014 | 04:39 PM
JEH03Vette's Avatar
JEH03Vette
Mine does the same thing. I think the AC comes on to dry the air regardless of the outside temperature. I too find it annoying.
To Heat
