Ipod Adapter
Old Dec 6, 2014 | 08:24 PM
bartsky's Avatar
bartsky
Default Ipod Adapter
Is the PXDP PXHGM4 the best ipod adpater for a C5 Z06 no cd changer? If so, do they still cause battery drain? Thanks...
Old Dec 7, 2014 | 12:21 AM
Give Dennis at Double D Mods a call - he can answer your questions on that device.
Old Dec 7, 2014 | 01:03 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I had one in my 2002 C5 and had no issues with the battery, It worked great, Like said above contact Dennis @ DoubleDMods.
Old Dec 7, 2014 | 09:52 AM
dadaroo's Avatar
dadaroo
Those iPod adapters work great. I installed one and brought the cable out the right of the console so I can have a passenger access it or I can lay my iPod in the seat or on the floor.
If you need info on how to access the radio, here is a link. You can stop once you can access the radio.
http://www.vetteessentials.com/instr...zel_howto.html
Old Dec 8, 2014 | 03:05 PM
tlove32's Avatar
tlove32
I just pulled my OEM head unit and Ipod adaptor (added an aftermarket head unit) and it's for sale. Let me know if you're interested.
Old Dec 8, 2014 | 04:06 PM
bartsky's Avatar
bartsky
Thanks for the replies...
Old Dec 9, 2014 | 06:05 AM
vela21975's Avatar
vela21975
How much are you asking for the Ipod adaptor?
Old Dec 9, 2014 | 03:13 PM
tlove32's Avatar
tlove32
$55 shipped
Old Dec 9, 2014 | 06:49 PM
Norm07's Avatar
Norm07
I enjoy my music, and with today's technology the CD is obsolete (IMHO). I tried the quick and easy way using an FM modulator. Didn't work very well. Ended up with a IPod interface from Double D Mods, run through the 12 CD changer. Purchased a used 8g IPod...there are plenty out there.. Ten minutes to install, real slick. All controls now on the radio head. 2000 songs at your fingertips with perfect quality. I just unplug it when I park the car. Happy, happy happy...best 80 bucks I have spent on this car yet.
Old Dec 9, 2014 | 08:49 PM
Clancy209's Avatar
Clancy209
Same as Norm07 I believe if you do not unplug ipod it will continuously charge.
Old Dec 10, 2014 | 04:28 PM
mrlmd's Avatar
mrlmd
How hard is it to get to the plug on the bottom of the CD changer in the storage area? Does the CD player just pull out or is there more to it than that?
Old Dec 10, 2014 | 04:38 PM
cmjuhl's Avatar
cmjuhl
Just bought the PXDP PXHGM4 one thru ebay for $55.00 shipped. Can't stand my CD player. Not sure on the battery drain.
Old Dec 10, 2014 | 05:08 PM
Clancy209's Avatar
Clancy209
u don't have to remove the CD player. Just reach underneath and unplug the wires, it has a side clip to keep it locked in. plug the harness in, then the adapter, set DIP switches (the instructions will tell you which numbers) to on. Position wire with the IPOD jack and run it up to the passenger cabin or where ever you want to keep the IPOD
Old Dec 10, 2014 | 09:06 PM
mrlmd's Avatar
mrlmd
Thanks for the info.
Old Dec 11, 2014 | 10:04 AM
3tt3v8P's Avatar
3tt3v8P
Dennis fixed me up with the adaptor and the speaker upgrade. A very simple install and sounds great. No battery drain (no more than normal) but now I have to get Dennis to fix me up with a sub and amp setup to really put the finishing touch on it.
Old Dec 11, 2014 | 05:11 PM
Sam Handwich's Avatar
Sam Handwich
Not difficult. Remove a couple of screws (maybe 4 screws?). And then unplug the wiring harness. I was not able to disconnect the cable until I detached the jukebox from the bracket.
To Ipod Adapter
