Idle Question
Old Dec 11, 2014 | 04:56 PM
travbjork's Avatar
travbjork
Default Idle Question
Hey guys,
I have a somewhat rough idle which gets a little worse when warmed up.
I do have a small coolant leak from a crack in the hose that goes to the reservoir, but no overheating and it's filled up. Highest I've seen it get was 210-220 in Texas Summer Traffic. It's next on my list.
I assume that if there's a bubble or something in the cooling loop, it may cause a rough idle due to temperature differences.
Should I start with plugs and wires? Or look at cooling? Also, do the coil packs ever die on your Vettes?
Any advice would be great
Travis
[2003 Black Convertible, M6, ~60k miles]
Old Dec 11, 2014 | 05:46 PM
JR-01's Avatar
JR-01
Try cleaning your Mass Air Flow sensor and throttle body. It won't cost anything(except the cleaner) and its a place to start.
Old Dec 11, 2014 | 08:59 PM
bjones7131's Avatar
bjones7131
Is it constant or just every now and again, u say somewhat, define that if u could. I have an occasional skip or rough idle and it has gotten better after running seafoam in gas and i opened up my stock air box for more air and this has helped. I hardly notice it anymore. Plugs and wires certainly would not hurt. I cleaned maf and throttle body and saw no improvement. I have read on this forum that it is somewhat charastic for a little skip/shake at idle. I drove a 2010 grand sport today and it had a little shake or rough idle, go figure. Good luck, let us know if u solve the problem.
Old Dec 11, 2014 | 10:48 PM
Originally Posted by bjones7131
Plugs and wires certainly would not hurt. I cleaned maf and throttle body and saw no improvement. I have read on this forum that it is somewhat characteristic for a little skip/shake at idle.
You could also try some injector cleaner to see if that helps.
Old Dec 12, 2014 | 07:19 AM
runner140*'s Avatar
runner140*
Start with the easiest and cheapest first. Run a can of SeaFoam.....
1/2 in the gas tank and the other 1/2 in the vacuum hose of the brake booster.
Check for any codes on your DIC.
Clean your mass air and your throttle body.
Do the above for starters.
Old Dec 12, 2014 | 07:23 AM
dadaroo's Avatar
dadaroo
When you have issues, always pull your DIC codes to see if they show anything. That is where you start. If you don't know how here is some help via a video and write up.
READING YOUR C5 Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
NOTE!!! Start the car and let it idle. Then take it for a drive and cause the problem to occur. When you return home pull the codes BEFORE you shut off the engine.
Do NOT discount the codes with the H following them. They can provide an audit trail for issues going on with the car. They ARE important in diagnosing problems.
Post ALL the codes that you pull with the engine running..........
Some codes go away WITHOUT setting an H code when you shut the engine off. I suspect you will have several codes that will show C or HC that do NOT show when the engine is turned off.
Old Dec 12, 2014 | 02:02 PM
travbjork's Avatar
travbjork
Hey everyone,
Thanks for your replies. I know how to use the onboard diagnostics... In constantly clearing P0410 haha, but no other problems.
I ran seafoam through the tank, but haven't done the vacuum trick on the Vette. I know my BMW loved it, but didn't wanna break my C5.
I'll clean the MAF and throttle body. I'm due for an air filter anyway and start there.
With that said, could my cooling, in theory, worst case, be causing it? Just curious from a knowledge perspective.
Thanks again,
Old Dec 12, 2014 | 03:17 PM
bjones7131's Avatar
bjones7131
I don't think the coolant issue would cause the rough idle, just my opinion.
Old Dec 13, 2014 | 07:50 AM
dadaroo's Avatar
dadaroo
Forget cooling. At least pull one plug and look at it.
To Idle Question
