oil catch can content
Old Dec 28, 2014 | 12:48 PM
RockJustBelow's Avatar
RockJustBelow
A couple of years ago I posted the question What's in my catch can? I had something very similar in my catch can. I haven't been concerned about it since.
Old Dec 28, 2014 | 12:57 PM
Bill Vett's Avatar
Bill Vett
This is what I got after 200 mile trip this past summer. I have never checked it during the winter since I don't drive it that much.
Old Dec 28, 2014 | 01:01 PM
momo20's Avatar
momo20
to the OP based on your mounting location which nothing is wrong with it at all imo, but could water be seeping in around the top part of the fitting and mixing with the oil?? i.e. water setting on top of the catch can and somehow seeps past the fitting into the can? would not take much to cause that ...just food for thought if at all even poss.
Old Dec 28, 2014 | 01:37 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Originally Posted by Mr.Bill
I have had my catch can for some 5 years and have never seen anything like, In my opinion it is not normal.
I check my catch can about once every year or so and have never had more than just a small amount of oil in it. Never had foam like that.
Old Dec 28, 2014 | 01:51 PM
drtyTshrt's Avatar
drtyTshrt
I switched the hoses to the correct location.
I had been driving in the rain since I installed the can.
I shall see.
Old Dec 28, 2014 | 03:17 PM
StingrayRebel's Avatar
StingrayRebel
looks fine to me, I ran a catch can for about 3 years and it always looked like that... I have it vented to atmosphere now and no pcv system and when I drain the breather it's basically like water with an oil/gas smell to it
Old Jan 21, 2018 | 12:06 AM
drtyTshrt's Avatar
drtyTshrt
More of the same.
It has never been just black oil.
I could spread some of this stuff on toast.
Old Jan 21, 2018 | 05:22 AM
GabeNation's Avatar
GabeNation
Looks like a slightly sub par cappuccino to me.
-Gabe
Old Jan 22, 2018 | 04:03 AM
ErikwithAK01's Avatar
ErikwithAK01
This buildup shows up every year I do my winter oil change.
When you let a C5 sit for a month or so, and then putz around town a bit, the condensation goes to the top when you heat cycle, causing this effect on the oil in the area. I just did my oil change for the winter last weekend myself, and I had this under the cap. I pulled the valve cover, and everything was fine; infact, cleanest internals I have ever seen for a car about to roll over 98K. The same can happen in your catch can.
Make sure your PCV valve is free breathing, and take it out for a mean run for an hour or so once it's hot. If the milky concoction continues to come back, then it's time to start performing some tests.
IF I WERE YOU, in the interim, I would pop my throttle body off and have a peek in the intake manifold. I would probably even change the oil for cheap insurance. If it persists, I would do a compression, and leak down test, and open the coolant cap when you do the leak down so you can hear if the compressed air is making it's way into the coolant passages somewhere.
Old Jan 22, 2018 | 01:42 PM
foggy's Avatar
foggy
The Content is absolutely normal.. It's moisture, fuel, Crap, Oil All mixed up ..
I have a vacuum pump on my 422 ci SBC and get out way more junk than just that..
Just remember, It's crap that is NOT going back into your intake/ engine/ Oil ...
So it's a good thing. It's doing exactly what it/s intended..
If you are not having to add oil or coolant.. Then No worries..
As a side note: The DIC oil change interval is not always the best guide.. change it
way more often..
Old Jan 30, 2018 | 11:31 AM
David@MMS's Avatar
David@MMS
Supporting Vendor
looks delicious!
also check that the pcv front line (either to top of tb or to air bridge) is not blowing oil forward of the throttle blade. this happens as the engine wears, during long periods of aggressive driving, or as power increases.
if it is then this oil your current setup is not addressing.
__________________
Solutions for the common gearhead #made in USA
mightymousesolutions.com
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
Old Jan 30, 2018 | 12:42 PM
FrankLP's Avatar
FrankLP
Miles of Smiles
2016 C5 of the Year Finalist
I have an Elite Engineering catch can on my car and have never seen anything like that in the reservoir. Every time I check it just has black oil in it.
