Passenger window not owrking
Old Dec 31, 2014 | 10:37 AM
Slade Kemp's Avatar
Slade Kemp
Navigator
Default Passenger window not owrking
My 04 passenger stopped working, again. My Buddy and I beat on the motor and all the other "tricks" we have heard and red...nothing.....we have a new windown motor and moduletoo. We checked everything and all my parts work BUT no up or down. He has 01 and all parts are same...
The one thing we noticed was the plug in for the motor had been cut and spliced in past.....been working since I got in July except 1 time.....any ideas?
Old Dec 31, 2014 | 11:13 AM
dadaroo's Avatar
dadaroo
First step would to jumper 12 volts directly across the motor and see if it works. If it does then we can work backwards to the power and ground to find the problem.
Old Dec 31, 2014 | 11:42 AM
Slade Kemp's Avatar
Slade Kemp
Navigator
We have checked it all...motor works....
Old Jan 1, 2015 | 07:07 AM
dadaroo's Avatar
dadaroo
So the motor works and will make the window move when jumpered?
What is the Module Part number you put in the right door?
The window will not go up or down from either door control, correct?
Make sure I/P fuse 30 and 31 are good.
Check ground G202 at the right A pillar by the door.
Old Jan 1, 2015 | 06:57 PM
DanSavage's Avatar
DanSavage
Check for bare wires in the door jamb.
https://www.corvetteforum.com/forums...ndow-inop.html
To Passenger window not owrking
