C5 stability
Old Jan 3, 2015 | 06:27 PM
motoman250f's Avatar
motoman250f
Default C5 stability
Anybody notice when they first started driving a C5 that the rear end kind of hunted around a little? maybe its just the way independent rear suspension is but it feels to me like I'm wanting to counter steer and I don't really trust the rear end when hitting normal bumpy sealed pavement. Might be the width of the tires too cause the front wants to grab the wheel from your hands when your in indented wheel tracks and I know that's partially from the wider tires. I'm not used to performance cars either so it could be me??
Thanks for any perspective!
Old Jan 3, 2015 | 06:36 PM
k24556's Avatar
k24556
What tires do you have? the Goodyear F1's have a reputation of following a groove in the road when they get older. I think it is called "tramlining" Usually a switch to a better tire solves the problem. It will feel like the car is wiggling, if that helps describe. I usually felt it when I was on a road where there was heavy truck traffic and the trucks put a depression in the asphalt. If you can find some fresh pavement and dirve on it and still feel it, then this isn't the problem.
Other than that if you have a loose suspension component like a tie rod end. That may be it too. The tire rod ends on these cars are tough, so it might be the connection of the rear tie rod to the transaxle cross member, which is a stud- nut. Also, may be loose sway bar links, another common problem. If your car is low mileage, under 80k, I would first suspect tires, though.
I had that on a C5 I had several years ago and a switch to Michelin PS2's stopped it.
Old Jan 3, 2015 | 06:40 PM
spdislife's Avatar
spdislife
Alignment could also be an issue.
Old Jan 3, 2015 | 07:02 PM
oldschoolvette's Avatar
oldschoolvette
No not at all
maybe you have a mechanical issue or a tire issue?
Old Jan 3, 2015 | 07:56 PM
Bill Vett's Avatar
Bill Vett
Your profile isn't filled out so I don't know where you live, that said if you are in an area that sees temperatures in the 30's and low 40's in the winter and you have summer performance tires you will have an unstable feel till the tires warm up and get some grip. If you live in a warm area then check the tire pressure (30 psi cold) if that doesn't help and the tires are in good shape you may need to have a 4 wheel alignment.
Old Jan 3, 2015 | 08:02 PM
raff's Avatar
raff
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22
I'd start with the basics --
Have you checked the tire pressure in all tires ?
Are the tires a "matched" set -- in terms of brand and size (front to rear)?
How old are the tires?
Are they showing any unusual wear patterns?
Old Jan 3, 2015 | 08:36 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Originally Posted by oldschoolvette
No not at all
Old Jan 3, 2015 | 08:37 PM
Koufax's Avatar
Koufax
Are running old run-flats? If so, ditch them.
Old Jan 3, 2015 | 10:32 PM
I haven't had the OEM tires on my car for over 4 years, but with the Hankook Ventus V12s that are on there now my car does not follow any grooves in the road - it goes straight and true.
Old Jan 3, 2015 | 11:34 PM
striper's Avatar
striper
You must have a worn suspension component, a tie-rod end maybe? I have to agree with the others on here. I've got a Z06 that has 130k miles on it and I have never had that issue. Unfortunately for you, it is not a common problem and seems like it is just your car that needs checking out. Could also be a worn bearing too.
Old Jan 4, 2015 | 12:31 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have a 2002 Coupe with Z51 suspension and lowered on stock bolts and stock shocks with 71K miles on it and it handles great like it is on rails.
Old Jan 4, 2015 | 12:50 AM
BitchinV's Avatar
BitchinV
Mine does the same thing. 2001 with 60k miles. Driving it back from Colorado to UT was downright scary in some parts. It has Michelin run flats on it. Im going to try new tires when I get my new wheels and an alignment and see what happens.
Old Jan 4, 2015 | 01:04 AM
bikeriderga's Avatar
bikeriderga
Alignment could be an issue, but I bet it is tires (or/and shocks).
You cannot believe how much of a difference top notch tires make on these vehicles.
When I had the Perelli PZeros on my Z06, they would spin with traction control on whenever I shifted at 3,000 RPM in first to second rather aggressively. If I really got on it, the wheel hop was terrible.
After I put Michelin Pilot Super Sports on it, well, it will not spin now when shifting at 4K plus. The tires stick like glue and the car handles like an entirely different car.
Don't skimp on your tires on a C5 Corvette. It is one of the best roadwise investment you can make.
Get rid of the run flats, they make way too much noise and ride like you are in a buggy. They will not catch either and if you are performing aggressive maneuvers will slide the rear end like grandma on ice.
One of the first things I did on my Base C5 coupe was ditch the run flats. Went to Michelins again and it made a huge difference, like night and day.
Old Jan 4, 2015 | 01:46 AM
motoman250f
Thanks guys! I guess I should have been a little more specific, I'm really talking about 2 problems. I know the front is likely tires or possibly alignment but the rear when its hitting bumps seems like its hoping sideways or something. this is a 98 with adjustable ride so maybe the shocks are getting bad. I'll do what you guys say, check tires, alignment, and suspension. Also I will be aware of the weather
Old Jan 4, 2015 | 12:38 PM
momo20's Avatar
momo20
I think the OP has some maintenance issue's he needs to address...my Z06 with OEM wheels, drives like a dream, I have never experience any of the items he is talking about,,
I would look at getting
Alignment
the condition or age of your tire's and maybe replace them
age/ condition of the shocks
sway bar
tie rod end link's
differential bolts ( that bolt it down to the rear support)
Old Jan 4, 2015 | 12:43 PM
91LSMAN's Avatar
91LSMAN
I would agree with this being that I drive my vette year round, and many of the roads in this area suck. After I drive for a bit and warm the tires, it feels like a different car.
Old Jan 4, 2015 | 01:46 PM
vettesmith02's Avatar
vettesmith02
To C5 stability
Old Jan 4, 2015 | 07:23 PM
WetteVette's Avatar
WetteVette
When I first drove my '97 with run-flats, the car seemed to be all over the road. Especially on freeways with rain grooves. A switch to non-runflats (BFG g-force KDW2s) immediately fixed that problem.
Old Jan 5, 2015 | 12:40 AM
Choreo's Avatar
Choreo
Had the same problem on these roads when my 2001 was "new". Car would start driving itself and I was just along for the ride! Could be any of the suggestions people have made above.
For me switching to Michelin A/S ZPs and installing C6-Z51 Sway Bars eliminated 95% of the problem.
Old Jan 6, 2015 | 11:04 AM
Stroker87's Avatar
Stroker87
my zo6 did the same thing on bumps the rear would jump and shift, I swapped the shocks and problem is now gone car rides better and is now planted.
