checking oil
Old Jan 9, 2015 | 09:51 AM
helives4u2's Avatar
helives4u2
Default checking oil
Hello, this might sound like a stupid question but does anyone else have a hard time reading the oil level on the dip stick? doesnt seem to be very easy to tell where the heck the oil level is,, Thank Mike
Old Jan 9, 2015 | 10:56 AM
john8642's Avatar
john8642
You could always lay the dipstick against a paper towel to see where the oil level is.
Old Jan 9, 2015 | 11:32 AM
CQRT's Avatar
CQRT
Funny - - if your oil is dirty, it's much easier to read on any car . . .but yeah - - clean oil can sometimes be hard to see the level - - light/angle has to be right.
It sure hasn't gotten easier as I've grown older !
Old Jan 9, 2015 | 11:51 AM
cessna10's Avatar
cessna10
cesssna10
Easily visible in daylight, not so easy in the garage
Old Jan 9, 2015 | 01:24 PM
JetMechZ16's Avatar
JetMechZ16
I have heard some people have drilled a very small hole at the upper and lower range limits of the dipstick. The oil will cover the hole if it's up to that level making it easier to see. I wouldn't do it to my car though cause I'd be afarid it might break off in the engine.
Old Jan 9, 2015 | 03:23 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I thought I was getting old and my eyes were going bad. I have a really hard time reading mine as well, even with a paper towel. My oil never gets really dirty, so it's kind of a pain in the butt.
Old Jan 9, 2015 | 03:35 PM
dharmadan's Avatar
dharmadan
Thanks!
Old Jan 10, 2015 | 12:31 AM
But if you take the tip of your finger and move it down the dipstick until you touch oil, it makes it easier.
Old Jan 10, 2015 | 12:41 AM
6speedsteve's Avatar
6speedsteve
BLACK SHARPIE
That is how I check mine works great, I just wipe off the dipstick with some lacquer thinner to remove all of the oil.
Old Jan 10, 2015 | 12:47 AM
ZeeOSix's Avatar
ZeeOSix
I always check mine when the engine is cold, always parked in the same spot in the garage. Makes it much easier to see the level on the stick.
Old Jan 10, 2015 | 05:41 AM
LoneStarFRC's Avatar
LoneStarFRC
Take some sandpaper and sand the area up to, and maybe a little above the full mark. I laid the dipstick on a flat surface and used some 120 grit wet or dry in a sanding block. Not trying to remove metal here, just roughen the surface.
The roughness allows the oil to be more easily seen against the "flat" non-reflective surface.
Old Jan 10, 2015 | 09:12 AM
CactusCat's Avatar
CactusCat
That's what I did. 4 very small holes in the end of the dipstick, 1 in the add oil area and 3 in the "acceptable" range area (bottom of range, top and middle). It will NOT "break" off in the engine... sigh.. Very easy to read the oil level.
Old Jan 10, 2015 | 11:00 AM
DevilDog II
Oldtimer
Think with your dipstick, Jimmy!
Old Jan 10, 2015 | 02:39 PM
jcgunn's Avatar
jcgunn
Um, is it possible that the oil level is VERY low and not making it to the dipstick...I'm just sayin'
Old Jan 10, 2015 | 03:41 PM
LoneStarFRC
Then there's always THAT!
To checking oil
