c5 plastic engine covers
Old Jan 14, 2015 | 01:55 AM
mikeurbas's Avatar
mikeurbas
Default c5 plastic engine covers
i'm old school and would like to remove the plastic coil covers over the engine. just thought i'd ask if there are any tricks to doing this, as I don't want to break any of the plastic mounting tabs. any help is greatly appreciated!
Old Jan 14, 2015 | 02:02 AM
StingrayRebel's Avatar
StingrayRebel
just pull them off
Old Jan 14, 2015 | 02:05 AM
mikeurbas's Avatar
mikeurbas
Default first vette
just pull them off
this is my first vette, and I just bought it in the middle of nov, 2014. just being over cautious.
Old Jan 14, 2015 | 02:30 AM
stu12dozen's Avatar
stu12dozen
Better to be over cautious than to damage something. Yes, they (fuel rail covers) pull off and go back on quite easily.
Old Jan 14, 2015 | 09:34 AM
They do just pop off but be careful when removing the driver's side - you have the braided fuel line that passes through the FRC and it requires you to flex the cover opening around the line in order to avoid scratching up the edges of the cover. I have put painters tape around the fuel line on mine (or a rag works well) to avoid the scratches.
To c5 plastic engine covers
