[Z06] Track Day got me hooked....
First thing I noticed was I slide around in my seat a ton! I am thinking A4s but for not super tall guys (5'8") and a short tick MC, I want to be able to sit fine.
I had TC and AH on, but sometimes out of a corner if i gave it to much gas, it would cut throttle for a second or two and seemingly kill my acceleration. I guess I am nervous to put it to competition mode.
My guess is I just need seat time before any mods, but I love buying stuff for the vette
Thanks guys
Cliff notes:
Fresh fluids
Decent set of pads
Learn the car
Have fun and be safe
My favorite quote when I posted the same thing you just did.
"Better get your Visa Jet Hot coated, its about to take some heat"
Funny and very true! A lot of time is needed too. Lot of prep/maintenance, lot of youtube watching, and a lot of time on this forum. There is a great thread in the sticky topics about prep'ing a C5Z for track duty. Tons of reading and good material there.
Welcome to the disease!
Read a ton on the autocross and road race forum..... damn there is a lot to take in. Seems like its easy to mod too much and it quits being a street car. Sounds like the same thing I did with my Jeep, too many mods and it isn't fun on the street anymore.
Regardless, sounds like spending more time there will be good.
Thanks guys
It costs some time and some fun to run with ah on, but its not really about cutting fast laps the first season or 2 its about learning how to drive on track. Where the line is, how and when to transition how much weight, and how to be confident in yourself and your car.
I still only run in comp mode and I do that cause at the end of the day I started way to late to ever be competitive at 30. I also run street tires to keep loads down so comp mode is very unobtrusive. I can say when I hit oil in 13 at Road America at 72mph I was glad it was there to keep me on track.
This season i am hoping to get the car to times it should be capable of with my tires. 16 season i will shoot for real consistancy. There is so much to running on track, patience in everything is the key to having a good time AND going fast imo.
The only mods i did was replace my 7 year old tires that came with the car. Replace diff, trans, and brake fluid at the begging of the season. Refresh the fluid in the calipers every track weekend. Put on proper track pads for track weekends. Also I had from my previous track days very basic telemetry/video on my iphone which is pretty valueable eventually. In the beginning you will be a bit clunky but looking back on it now its good for a laugh. There are a number of self contained apps that are cheap/free and worth having for understanding what you did right and wrong.
Last season i lost my trans, so i did all the trans internal, clutch, rebuild of the torque tube. I was also fast enough I started having some cooling concerns so i am addressing that before this season starts. Also replacing trunions and valve springs before they give me trouble.
I am confident i wont have any need for more power for at least 2 years. The car is just that damn good. Seats are on my short list. At 6'1" I can pin myself in with my knees well enough for street tires. Use the ratchet lock on the lapbelt it does help a significant amount, probably get you through a season, at which point you will likely have something to address with that 1k more important than seats. That is what happened to me.
If the day comes you go from hobby to serious hobby and you really want to refine your ability, so be it...go all in. There are situations at an HPDE or similar event where being in a "mode" can save you...spilled fluids, a car coming out of the grass, etc. I've known people fast in grip, that got very confident, but when the car departed grip to slip, they were more or less going for a ride...and they didn't like to admit that.
I wasn't really comfortable with this. I was told by others that this guy was a really good corvette instructor. So I convinced myself that if I stay at 7/10's and listen to my instructor all will be fine. It ended up being uneventful, but I didn't like the idea. All other runs since then have been with PCA groups and with AH on.
Mark
That is true. I have been very careful tip toeing that line myself. The biggest change is the seats. As soon as you go to a race seat and a harness, it becomes a PITA. You mentioned the A4. That's what I installed in my car trying to toe the line between street car and track car. I found a way to have both sets of setbelts installed in the car at all times. That helps. Even still its much harder to get in and out of the car than with the stock seats, the ride feels much harsher, and they are not good for the lower back on long drives if you don't have a great lower back. Also, I'm 6' and had to modify the brackets massively to get the seat to move forward enough and high enough in the front.
Do this. I'll add that you need to pull the seatbelt all the way out so that when you let it go it locks in place. Then move the seat up and let it squeeze the hell out of your hips.
Do this. I'll add that you need to pull the seatbelt all the way out so that when you let it go it locks in place. Then move the seat up and let it squeeze the hell out of your hips.I ended up buying some A4s about 2 weeks ago, and installed them a few days ago. Really enjoy the improvement!
2003 Z06, corsa extreme, K&N, Elite Engineering catch can and heel/toe petal, Fluidamper, Pfadt tow hooks, (4 Hoosier 315/30/18s on 10.5 Wheels waiting for more seat time)
doing lap days once a year can be a great experience though
make sure you sit in the seats before you buy them. i personally hate A4's and would use evo8 recaros for the street or a recaro pole position for the track
tires get wasted fast. if you get another set of wheels and a hard R comp like the toyo r888 you can go 3-4 seasons at 1-2 events a year no problem. this keeps you from killing your street tires
depending on the track a hot street pad like the hawk hp+ may be enough brake
another word of caution. race brake pads will kill the rubber booties on street brake calipers when you start getting glowing rotors and elevated temps for a period of time
