[Z06] Cleaning up Suspension...
Old Jan 25, 2015 | 11:07 PM
Breze84's Avatar
Breze84
Default Cleaning up Suspension...
So I put up a thread last year with a write up and pictures on how I cleaned up the uglyness under the fuel rail covers in the engine bay that plagues the Corvette's...
https://www.corvetteforum.com/forums...gly-wires.html
I am undertaking another project right now. Before I put my rims and tires back on I have removed my brakes/suspension components to paint/Clean anything I can before I put my rims back on.
If anyone has questions pertaining to it let me know. I will post more pictures as I get further along. The next process will have a lot of pics.
Here are a few teaser pics.
Rims & Tires Going On
Rear Swaybar / Bracket Before
After With New Endlinks To Go Along
My Rear Zink Plate Rotors Were Looking Sad. Left Is Aftermath, Right Is Before
Both Rears Done "If Anyone Is Curious Why My Rears Are Large, I Have 4 Way Front Calipers & Rotors
Front passenger while Cleaning
Front Passenger Side Done 3 more to go
Front Driver Side NEXT
Old Jan 26, 2015 | 03:17 AM
rjwz28's Avatar
rjwz28
It looks great! What are you using to clean everything?
Old Jan 26, 2015 | 10:58 AM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Nice job!!
I ended up installing new end links both front and rear as well.. Those plastic ones sure are crappy!
Old Jan 26, 2015 | 01:01 PM
Breze84's Avatar
Breze84
I used a degreaser product called "Zep Pride" and sprayed everything and scrubbed it with the green side of a spounge. I then sprayed the aluminum with a product called "Aluminum Brightner" from Napa, it is made by a company called Mac's. I let it fizzle up and rinsed. I then took some gray scotch brite and rubbed everything down and rinsed. Then went over it with some fine steel wool. The spindle i scrubbed with gray scotch brite dipped in CLR. Took about 2 hrs or so.
Also i used a small nylon type tooth brush to get in the tight places.
Old Jan 26, 2015 | 01:03 PM
Breze84's Avatar
Breze84
Originally Posted by PeteZ06
Nice job!!
Thanks bud. Yea my endlinks were trashed. although I didn't have the plastic ones, I actually had ball swivel heim joint ones. The car sat for a while and they froze up solid.
Old Jan 27, 2015 | 02:19 AM
rjwz28's Avatar
rjwz28
I'm just now putting all my stuff back together after almost a year... I should've done that to the whole chassis while I had it torn down, honestly
I did what I could with the rear subframe while it was apart, but some stuff just didn't want to come off and I wasn't interested in spending more time on it. Yours definitely turned out very well; I'll keep that method in mind for the future.
Old Jan 27, 2015 | 09:11 AM
Fast Cop's Avatar
Fast Cop
Looks great, nice job.
Old Feb 4, 2015 | 10:12 PM
bluestreak63's Avatar
bluestreak63
Looks great...now that's a labor of love...
To Cleaning up Suspension...
