So I have been pondering getting rid of the star wars plastic and cleaning up the spaghetti bowl of wires that plague the LSX Motors and clean the valve covers and motor while I was at it. Well today was the day I decided to start my mini project. I just got done pulling Coil packs, and started stripping the harness sheathing about a hr ago. I will be wrapping the wires with braided sleeve and using tiny zip ties about every 4" to keep it neat and clean looking. I will also be scuffing my coil pack brackets and repainting them along with cleaning up the wires for them as well. Then I will finish up by giving a halfway decent valve cover polish without removing them. I also Polished my crankcase relief combination catch can earlier today.
I will periodically update as I get time to work on it, I plan on finishing this up pretty soon though...
Previous Pics...
Day 1... 75% Teardown and polished Catch can, The harness wrap is a pain in the a$$, That's 90% of the battle lol..
I really like where you're headed with this project. I did some similar mods to mine last year. I got my valve covers and coil brackets powder coated along with some small fuel rail covers I made. Also painted the coils and some other accents in Ford blue engine paint. I look forward to the next pics.
Day 2... Didn't do much today really, I just stripped the coil packs down from the brackets and decided to remove my Valve covers because I have decided to do something a little different... What I plan on doing different now is I am going to paint me Coil pack brackets red and wrap the coil pack harness only with red tape so it blends in. I am also going to scuff my valve covers and paint them with VHT 350 degree Wrinkle Red. I just ordered everything so I should have it this week
Pretty candy under the hood, I have a LS3 sitting in my garage that I will build down the road to replace my LS6 but your LS7 looks so mouth watering
Thanks man LS3 will be nice...
Thanks man, Looks awesome...
Looking good so far. Subscribing to this to see further progress.
Day 3... sanded my valve covers starting off with scotch brite then I used a dremel with a fine wire wheel, I then finished it off with scotch brite again. The casting on the oem LS7 valve covers sucks and there is a lot of casting marks and pits... oh well, I may go back and really sand those spots down. I then blasted them down with some brake cleaner and cleaned them in the wash tub with dawn and dried them for paint. I then scuffed up the bracket a bit with scotch brite and rubbed it down with some reducer then shot it with some high temp red. The coil pack I just taped up the connector and plugged the plug hole with a cap, rubbed it down with some reducer only and shot it with some high temp black. I just did 1 bracket and 1 coil pack to make sure it came out the way I wanted it. I am letting it cure to see the results before I do the others.
DAY 4...Well yesterday I decided to pull my TB off because I wasn't happy with the oxidized gray aluminum look. Today I worked on everything from 7:45am-2:30pm. I got a lot done. I sanded and polished my TB which took a couple hrs, I block sanded my valve covers to get rid of any casting imperfections because I decided to just do them high temp gloss red instead of the wrinkle red. I also sanded and painted my other coil pack bracket and painted 3 more coil packs. I still have 4 more coil packs to paint and then I will high temp clear everything. Here are some pics...
First 10 mins of TB Sanding and Polishing
Here is the finished product. I ended up using my die grinder with a thin wire wheel, Then I went back with some scotch brite and finished up with some 4 ought steel wool. I used some never dull to bring out a shine.
Here is me prepping a coil pack for paint, No scuffing, Just tapped up the connector and plugged the hole. I use a paint brush with reducer, It makes it easier to get in all the nooks then I blow it down with air and wipe it.
Here is the driver side valve cover prepped, tapped and getting sprayed
