I have a 2004 Z06. The inside rear view mirror doesn't work. It is the auto dimming type and the green lite doesn't come on when I push the button. The lights under the mirror do not work and the vanity lights on sun visors do not work either. I checked fuse 21 and 2 and they are fine. I checked the voltages on the connector and I have 12V between pins 1 and 2(ground) when the headlights are on. I also have about 6V on pin 7 and 12V on pin 6 when the door is open. So there should be power for the mirror but it doesn't come on. Any ideas?
Reason: Typos
Do your reverse lights work ? My reverse light switch went bad and would stop the mirror from working also. Must be on the same circuit and the switch is a known issue. Very inexpensive to fix.
For my own clarification you are referring to these fuses located in the passenger foot well fuse panel?
Are the glove box light and the under hood light working??
If not I would check relay #37 in the passenger foot well fuse box.
The glove box i'm not sure but the under the hood lights are very dimm. I checked the voltage and it is only 6.5V. I'll check the relay tonight and report back. Thank you!
I appreciate all the suggestions. I replaced the relay and nothing changed but I found out that fuse #2 10A inside the footwell was blown. I replaced it and that fixed it.
