Master cylinder
Old Mar 6, 2015 | 06:02 PM
Clavicus's Avatar
Clavicus
Default Master cylinder
It appears to be leaking. Is the slave cylinder fed from the master cylinder in the 01?
Old Mar 6, 2015 | 06:16 PM
OneCylinder's Avatar
OneCylinder
St. Jude Donor '13
YES, if you're refering to the clutch master cylinder.
NO, if you're refering to the brake master cylinder.
Old Mar 6, 2015 | 06:24 PM
Clavicus's Avatar
Clavicus
Okay so there is no way that my issue with my break pedal could be from my clutch slave cylinder? Had a prior issue with clutch slave cylinder. So where does the clutch master cylinder get fed from?
Old Mar 6, 2015 | 06:46 PM
bumble-z's Avatar
bumble-z
Clutch fluid Reservoir under the hood feeds the clutch master cyl.
Old Mar 6, 2015 | 06:51 PM
Clavicus's Avatar
Clavicus
Thanks. Awesome new issue with her car haha. Just got to figure out were my brake fluid is leaking from.
To Master cylinder
