Hmmm. I'll be honest...I didn't even think about the 265s as they are kind of an oddball size. That might be the way to go for a little quicker turn-in and not much contact-patch reduction.
Thanks for the input and I'll talk to The Speed Depot today...
265/35-18 is the equivalent of the 265/40-17 that came factory on these cars and is available in most performance tires... how is that an oddball size?
Because 275 is common across many vehicles both past and present. I've had 275s on plenty of vehicles already including Corvettes and F-bodys. The C5Z is the only wearer of 265s that I am familiar with...
Thanks!
Ah, you were an F-body and C4 guy... 265s have been factory on Mustangs, as well as a bunch of foreign performance cars
why not 265/295 combo, same dia specs for tires as stock except 18 on front, what I have and zero problems.
change your order to 265 now, not even kidding, the 275 runs wide and will look very out of place with the rear which fits that 10.5 perfect, the 275 wants a 9.5 or 10" wheel. also will increase oversteer
You'll like the 18s up front, bit more responsive on turn in, the trade off is be a bit more careful of potholes. I run C5Z rears up front on the street to clear my brakes with the same tire size and I like the look.
I'm about to go this route to replace some Nt05's. What brand and size tires front and rear are you running?
